Power FC Datalogit not showing wideband values PLX
Old Aug 28, 2010 | 03:50 PM
r074r'/ |\|00B
I installed my PLX wideband today. I have the dashpod showing values (I hope correctly), but I'm not getting anything from my datalogit.
I connect AN1 to +5v and AN2 to ground.
Here's my setup:
Did I miss somehting?
Old Aug 29, 2010 | 10:02 PM
blue87's Avatar
The wiring sounds right but if you are using a diffrential input (using a1 nd a2) you should check the Delta AN1 - AN2 box, this will account for float ground differentials between the wideband and the datalogit... I had to use AN3 and 4 on mine since a terminal was broken from the board from being torqued too tight (by me oops) I don't know about your wideband, do you have to enable the analog output maybe?
Old Aug 30, 2010 | 06:50 AM
r074r'/ |\|00B
Did you use the filtering capactors in your setup?
Old Aug 30, 2010 | 08:57 AM
blue87's Avatar
I just hooked the analog out from the wideband controller right up to the analog in no caps... There may be some internal filtering on my wideband? Signal is pretty clean I am using the innovative lm2 I think that is the model number? ...
Old Aug 30, 2010 | 10:24 AM
r074r'/ |\|00B
I'll try again tomorrow with that box checked. Tonight I have class so no time for toys.
t-von
Sep 10, 2015 01:56 PM
