Beeping/ No Speedometer or Odometer
Old Jun 27, 2002 | 10:41 AM
MoDice7's Avatar
I have an 86 RX7 GXL. Yesturday when I started up my car the speedometer and odometer failed to function and roughly 2 minutes down the road, a beep started to go off. All other guages work and the car seems to run fine. This process continues each time I drive the car.
Anyone know what the beep is or how to fix these guages?
The sunroof is stuck on the left side and only opens on the right until getting stuck. Anyone know how to fix sunroofs?
Old Jun 27, 2002 | 10:45 AM
Icemark's Avatar
the beeping is more than likely from your power steering computer, as without the tach signal and speed signal it is going into an error code.
For the sunroof the search function found in the top right hand corner of this page, just below the picture of the car.
Old Jun 27, 2002 | 10:55 AM
Josepi's Avatar
Despise Enmity
Speedo cable.
Cleaned the tracks and hosed em with silicone spray yet?
Old Jun 27, 2002 | 04:29 PM
MoDice7's Avatar
The seedometer cable would have something to do with the milage stopping?
Old Jun 27, 2002 | 09:03 PM
NZConvertible's Avatar
I'm a boost creep...
How else do you think the odometer works?
Old Jun 27, 2002 | 10:14 PM
kristopher_d's Avatar
Ummmmmmmm. http://www.howstuffworks.com/odometer.htm
Old Jun 27, 2002 | 10:38 PM
WonkoTheSane's Avatar
Green Flameless
trust em on this one, it's the speedo cable? How i do i know? I just replaced mine last week after it came loose from the tranny and the middle part (the actual cable) came out.. go down to Advance Auto, i picked mine up for 20 bucks... however, i couldn't get the oem gasket to work around the firewall, I still haven't come up with a solution there yet.
Old Jun 28, 2002 | 10:14 AM
awitte's Avatar
If anyone has ever had to push-start their car you may rember hearing the same thing. Basically the car thinks it's moving without the engine running. Speed-o cable is the best bet.
A/.
Old Jun 28, 2002 | 01:45 PM
OK, this just happened to me two weeks ago, here's the easiest fix:
First off, the beeping is your power steering computer. You can turn the car off (make sure it's in neutral) and turn it right back on, and that will give you 2-3 minutes of peace and quiet.
Go and get a new speedo cable. DO NOT REMOVE THE OLD CABLE HOUSING. Simply take the new cable out of the new housing and slide it up the housing which is already in place in the car. You will save yourself an hour and a half as well as not needing to remove the steering wheel and half the dash.
Old Jun 28, 2002 | 01:48 PM
Also, my sunroof doesn't work that great, mostly because it is 15 years old... Get yourself a childs toothbrush and some wd-40. Spray it on the toothbrush and clean out the tracks with the sunroof all the way open. Now, bring the sunroof all the way forward, leaving it popped up, and clean the tracks underneath. That will help it, but odds are you are going to have to take it out of the car and take it apart to get it really clean... This will at least buy you some time.
Old Jun 28, 2002 | 02:13 PM
blu_gxl's Avatar
um... you can't just use the inner cable it's a matched set you have to get both the inner and outer cable
james
Old Jun 28, 2002 | 08:06 PM
SerpentineGX's Avatar
It's your speed cable. If you noticed, the power steering stiffin's at slower speeds and just kinda stays that way. I have the same prob right now. Try www.mazdatrix.com. They seem to have a lot of things. That's were I'm going to get it done at (eventually). For the mean time, crank up the tunes
Old Jun 28, 2002 | 09:38 PM
Evil Aviator's Avatar
Rotorhead
Just a thought, but maybe before you start tearing parts out of your car, you may want to simply put it up on jackstands and make sure that the speedometer cable is snugly screwed onto the transmission. See the transmission section of the Factory Service Manual for a picture of where the cable attaches.
Old Jun 30, 2002 | 09:21 PM
kemozabi's Avatar
.....shhh hes coming.....
and if the cables plugged in under the car u might wanna check behind the dash before u get a new one. and i hear silicone spray is better for lube than wd-40. just search youll find just about anything
Old Jun 30, 2002 | 09:31 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
hey this is my bag baby!!!!!!
is it a five beep series?? i have a whole thread that goes over everything in the steering system search under my name and "technician"
Old Jun 30, 2002 | 10:39 PM
sandmstreet3's Avatar
i had same problem, i just re-connected the spedo cable and everything was back to normal!!
Old Jun 30, 2002 | 11:24 PM
Amur_'s Avatar
Refined Valley Dude
That thread is why God put you on this earth, dude. We can put you to pasture now. Turn in your key to the men's room on your way out.
Seriously, that thread is a 7 owner's mini-Bible to attacking p/s computer whining. Give RX-7Impreza your love. He's earned it.
https://www.rx7club.com/forum/showth...threadid=39689
rx7nepal
Jun 8, 2022 10:04 AM
rgordon1979
40
Mar 15, 2022 12:04 PM
Coochas
44
Nov 5, 2019 11:08 PM
