only when turning left
Old Aug 14, 2010 | 04:43 PM
immortalmcf's Avatar
hello,
i have a second gen. it was an n/a but i converted into a tII have a few mods and i'm having this problem for a really long time and nobody been able to figure it out.
here it is the car acts like it wants to shut off only when i want to make a quick left, it bugs out for a few secs. and then it goes back to normal. i already put a new pump, tps, fuel filter, throttle cable and none fixed the problem i was told by different people that those things were causing the problem so i replaced them but nothing same thing when turning left. also it does this regardless if the tank is full or 1/4 tank. i already looked in faq, and 2 gen specifics, any ideas would be truly appreciated.
thanks
Old Aug 15, 2010 | 10:25 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the fuel tank baffles.
Also, is your battery tied down? Maybe the cable is rubbing.
Old Aug 15, 2010 | 02:14 PM
yeah my baterry is tied down, it might sound dumb but what is the fuel tank baffle? my english is not that good so there might be words that i have no idea what thet are lol.
Old Aug 15, 2010 | 02:37 PM
Aaron Cake's Avatar
Engine, Not Motor
In the fuel tank there is a wall surrounding the pump which prevents the fuel from moving away from it during turns. Perhaps yours has come loose?
Old Aug 15, 2010 | 02:41 PM
ahhhhhhhhh ok am gonna check that out thank you.
Old Aug 15, 2010 | 02:42 PM
and if its broken do i need i knew fuel tank?
Old Aug 15, 2010 | 03:49 PM
also will the baffle affect it even if the tank is full of fuel?
Old Aug 15, 2010 | 06:17 PM
Go48's Avatar
You changed the "fuel filter". Did you change the fuel sock located on the fuel pump? That has been known to cause the problem you are experiencing.
Old Aug 17, 2010 | 02:06 AM
jeremyqueenerracing's Avatar
Check for pinched fuel lines. Its not getting enough fuel for some reason.
Old Aug 17, 2010 | 03:01 PM
damn now that you guys mention it i didnt change the filter or the sock that comes with the pump thanks a lot for the advice am gonna switch those things hopefully that will do the trick.
Steven_McKinley
Sep 5, 2015 10:48 AM
