pinting wheel wells and underbody
Old Aug 14, 2010 | 12:53 PM
AchillesGr's Avatar
hi,
i wire wheel some rust at the wheell wells and need to spray that black chip protection again.
there is a bare metal spots (about 3"x5") .
my questions:
a)what coats do i use before the black corosion and chip protective layer?
1. etch primer then 2k primer?
2 etch primer then epoxy primer?
3.epoxy primer only?
b) is the etch primer overspray bad on the other areas? i try to spray some at the bare metal and i had some overspray about 2". is it ok to leave it upon the previus protective stuf?
can someone please suggest?
the final protective stuf will be a terotex super 3000 pruduct by henckel-loctite that it is eassy to find here in greece. i do not know if anyone of you have experience with that.
parhaps you are using completely diferent products but it is hard or imposible for me to find.
thanks!!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
