Difference from turbo II differential and N/A differential
Old Aug 13, 2010 | 01:35 PM
insanekiller18's Avatar
Hi just wanted to know how to tell the difference from Turbo II differential and N/A. I looking at buying a 1990 Turbo II differential and just want to make sure it LSD. It is out of the car. What is the best way to test it? Thanks
Old Aug 13, 2010 | 01:49 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I've never tried it myself, but it's said that if you spin one half shaft/flange the other side should turn the same direction if it's an LSD.
All TII diffs are LSDs, and they use a larger ring gear than the NA diffs (8" vs. 7"). There will be a tag on the drain plug that says something about it being an LSD, and the number of ribs on the case is something like 13. My NA S4 LSD has 11 ribs on the case, and I know the TII diffs have more due to the larger size.
Old Aug 13, 2010 | 03:35 PM
Thanks for your help.
Old Aug 13, 2010 | 04:27 PM
Z3r0 s1gnaL's Avatar
Shark Flap
Since you say you've never tried this, I'll jump in and inform you that this is 100% true.
Queppa
Nov 18, 2024 03:47 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
