revs to 2k then dies out
Old Aug 12, 2010 | 01:15 AM
vintage.02's Avatar
i just got this 90 gxl na and a couple of times after the car has sat for about 5-ten minutes the car wont rev past 2k. it starts and idles fine but when i press down the accelerator it revs up to 2k rpm then almost stalls and goes back down to about 500 rpm. it will do this over and over. the first time was about five minutes after i washed it, i started it up and drove away from the car wash and went a quarter of a mile to a gas station. it sat there maybe five min and after i started it it wouldnt rev. after about ten minutes it was fine. i was thinking something got wet but all was dry in the engine bay. the sec time i drove it home and it sat for an hour then when i went to leave it did the same thing. five min later it was fine. im new to rotaries so could someone point me in the right direction thanks.....marc
Old Aug 12, 2010 | 11:28 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Start with pulling codes: http://www.johnr.com/cpucodes.html. It sounds temperature related, so my first guess would be the water temp sensor on the back of the water pump housing. The ECU needs this for fuel corrections.
Old Aug 12, 2010 | 02:03 PM
vintage.02's Avatar
great thanks i'll try that and see what it says.......marc
Old Aug 13, 2010 | 09:56 PM
CrimsonPride's Avatar
If that doesn't solve it, I would next check the TPS, AFM, and rev the engine and with a stetoscope listen for proper operating sounds from each of the secondary injectors.
Old Aug 15, 2010 | 12:23 PM
Top Down, Boost Up
Secondary injectors do not fire until 3800+ RPM and greater than -2 inHg vacuum. There wouldn't be a point in suspecting them.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Prediict
32
Nov 18, 2015 08:41 AM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
