Smog check help
Old Aug 9, 2010 | 08:39 PM
Linx7's Avatar
Smog check help
I just got my smog check done and my car didnt pass. I need some help finding out what could it be. I changed my spark plugs and air filter so far, it runs rich and has high CO level. what can i do before i spend more money?
Old Aug 10, 2010 | 01:24 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Post vehicle information.
If 2nd gen, see the FAQ for information on smog test results & what they mean.
Old Aug 14, 2010 | 10:04 AM
misterstyx69's Avatar
Retired Moderator, RIP
Get a Hi Flo cat,,rotary engines burn the **** out of Catalytic converters Quickly.
Check the cat by Removing it or Tapping on it to see if the "Innards" are still in the cat!..Meow!haha.!
I had a RX7 that failed Miserably,the previous owner had Removed the Guts of the catalytic.
Btw,Rotaries run rich all the time.(unless you get a standalone or something to control fuel).
Old Aug 16, 2010 | 02:19 PM
funkjaw's Avatar
Post specs about your car and the actual numbers of the failed smog test.
Do you have:
Working airpump?
Working cat?
Working o2s?
Working EGR (S4)?
Competent smog technician?
If so, your car will pass fine.
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
Tem120
Sep 7, 2015 09:53 AM
rotor_veux
Sep 3, 2015 07:10 PM
