High(er) amp source
Old Mar 19, 2001 | 01:53 PM
Coolidge's Avatar
Run 4-gague power/ground for your amps...this way you dont have to upgrade to bigger cable when you upgrade your system if you ever do in the future. The extra $5 the cable will cost is worth not haveing to remove the old stuff and put in new stuff and buy all new stuff.
The only time you will need more than 4 gauge is if you are pushing SERIOUS power from your amps (ie: 2000+ watts)
Current Project= 13B turbo in 1987 MR2
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
