Enkei RP-F1 17X9.5 +38 up front on an FD?
Old Aug 7, 2010 | 03:20 PM
books's Avatar
I am considering an Enkei RP-F1 17X9.5 +38 in the SBC finish on my lowered FD (Eibach springs).
Using Jimlab's spreadsheet it appears the offset may be too small for the front; -0.26" for tire clearance outside.
I realize the most recommened size for 17s up front is 17X9 with a +45, however that size does not have the SBC finish.
Has anyone used th +38 on an FD?
I assume the tires would rub on the outside.
Would a slight fender roll allow them to fit?
Old Aug 7, 2010 | 03:35 PM
Mahjik's Avatar
Mr. Links
If you roll the fenders and maybe use a slightly more narrow tire it will work.
Old Aug 7, 2010 | 05:35 PM
books's Avatar
Thanks Mahjik,
what size width are you thinking? 255 or less?
Old Aug 7, 2010 | 05:45 PM
Mahjik's Avatar
Mr. Links
A 245 or 255 should work just fine up front with a roll. If you get a little more aggressive with the roll, you can add more meat up front.
Old Aug 8, 2010 | 02:13 AM
books's Avatar
thanks so much for the help!
