Whats the best place to get adjustable rear camber bar? also has anyone made one?
Old Aug 5, 2010 | 06:40 PM
mikemclain11's Avatar
i need a rear camber bar and it needs to be adjustable i was wandering where is the best place/ or some dimensions on somesone so i can make my own
Old Aug 5, 2010 | 06:49 PM
prrex4ever's Avatar
Now What?
What kind of "7"? Racing Beat has one for FC's, I had one on my 88 GTU.
Old Aug 6, 2010 | 11:41 AM
j9fd3s's Avatar
Community Builder
a friend of mine cut the stock one, it really really sucks to do it that way. basically you cut, weld it up and put it on and see where it is, take it off cut more and reinstall etc etc
the part that really sucks is getting the short link back IN the car.
if you have more money than time, just buy one. if you have more time than money, roll your own
Old Aug 6, 2010 | 11:45 AM
frijolee's Avatar
the implications matter
AWR and MMR both sell individual adjusters that are far superior to the single link route (that screws with your pinion angle as well).
If you really want to do it right you want to pick up the spherical bearing LCA pivots as well (the individuals don't play well with urethane or stiffer materials, stock has enough compliance that you'll be OK).
Old Aug 6, 2010 | 12:54 PM
sen2two's Avatar
Rx2 > FD
I made my own. Which is cool cause i can make it to whatever spec i needed it to be. But you would need a lathe to do it...
matty
Jan 18, 2020 10:39 AM
RaY358
Aug 19, 2015 11:44 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
