Starting problem
Old Aug 3, 2010 | 04:25 PM
Throwsonis's Avatar
Loose Gasket
Starting problem
I'm having trouble with my FC.
When i try to turn it over, the starter, and everything works, then as soon as you hear it turn over it dies unless i keep my foot on the pedal and keep the RPMs above 5k.
Could it be electrical, or fuel pump?
Old Aug 3, 2010 | 05:08 PM
RotaryRocket88's Avatar
Top Down, Boost Up
That sounds more like an idling problem. Will it idle at all after you warm it up? Check for vacuum leaks, leaks in the intake piping and test the TPS.
http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
http://www.johnr.com/tps.html
Old Aug 3, 2010 | 05:35 PM
Throwsonis's Avatar
Loose Gasket
no, it wont idle at all, and we replaced all the vaccum hoses, and a brand new intake and TPS.
I forgot to add that its an '88 TII
If anyone knows of any garages that work on RX-7s here in San Diego, CA, i would be much appreciated to know!
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
