1988 Non turbo starting problem
Old Aug 1, 2010 | 10:37 PM
bgbur98's Avatar
The exhaust is not hooked up yet, I have all new fuel lines, new pump and new filter. I can get it to start, but it only runs for a few seconds and shuts off. Any ideas... could this be related to the security not being hooked up? Are there any ways to bypass?
Old Aug 2, 2010 | 10:26 AM
Aaron Cake's Avatar
Engine, Not Motor
Is the AFM plugged in?
Old Aug 2, 2010 | 11:07 AM
satch's Avatar
If the AFM is plugged in then jumper the fuel check connector and verify that the fuel pump works when the key is turned to the on position.
If you have the factory alarm, it would prevent you from starting the car at all. If you wanted to bypass it you would jumper the Black/Green wire to the Black/White wire at the starter cut relay plug.
Kyo
Apr 13, 2019 09:24 AM
sherff
Feb 24, 2019 12:09 PM
alphawolff
Nov 17, 2015 05:57 PM
