offset question
Old Aug 1, 2010 | 10:24 PM
FD3TT's Avatar
offset question
I have a 19x10.5 et +15 does adding a 10mm spacer make the offset +5 or +25?
Old Aug 1, 2010 | 10:30 PM
Mahjik's Avatar
Mr. Links
Originally Posted by fd3tt
i have a 19x10.5 et +15 does adding a 10mm spacer make the offset +5 or +25?
+5
Old Aug 2, 2010 | 07:17 AM
gio64's Avatar
I'm confused
Not trying to open a discussion, but wouldn't this actually increase the offset?
What I know (if correct), is that positive offset means that the centreline of the wheel lies between the hub's face and the outside of the car.
If you put a spacer in, this would move the entire wheel (and therefore its centreline as well) towards the outside of the car, thus increasing the offset.
I was told (or I read) that a spacer can only reduce negative offset or increase positive offset.
Please, Mahjik, could you clarify, I am not buying spacers, but I'd like to be corrected if that's the case.
Old Aug 2, 2010 | 07:25 AM
gio64's Avatar
Never Mind
Never mind, I just woke up.
I realized that it is the opposite of what I said.
Sorry
Old Aug 3, 2010 | 10:06 AM
FD3TT's Avatar
+5
Thanks.
_Tones_
May 25, 2021 05:37 AM
