bigger Throttle Body is it worth
Old Jul 27, 2010 | 09:35 PM
QuangRX-7's Avatar
just want to know is it worth getting my throttle body bore to b 4mm lager its about under 800 to get it done
Old Jul 28, 2010 | 09:17 AM
Aaron Cake's Avatar
Engine, Not Motor
Generally, no.
But since you have given absolutely no information about which car you are referring to, it is hard to say.
Though if your car is making less then 600HP, it's not worth it.
Old Jul 28, 2010 | 07:44 PM
QuangRX-7's Avatar
thanks for the info i have a 94 mazda rx7 street port to4r etc... still braking in the motor so i dont know really know wats it putting out for hp but the guy who did my motor said i should b getting over 450hp to the wheel on 12lb boost
Old Aug 1, 2010 | 03:10 PM
amxone's Avatar
I have the same question but looking for an upgrade to replace my stock throttle body
DerpyToast
14
Nov 23, 2024 05:19 PM
gabescanlon
Sep 5, 2015 12:09 AM
