Microtech staged injection misfire/small hesitation
Old Jul 27, 2010 | 08:21 PM
arc_55's Avatar
hey guys, I have tuned this t2 engine very well but i am curious to know how i can fix my staged injection hesitation. I have it set for 3000rpm and i have a slight misfire/hesitaiton type feeling exactly at 3000 rpm. What screen can help me fix this issue. Should i raise the rpm point?
Thank you
Old Jul 28, 2010 | 09:05 AM
Aaron Cake's Avatar
Engine, Not Motor
So what are your injector sizes?
Old Jul 28, 2010 | 09:12 PM
PDF's Avatar
PDF
Try lowering the stage rpm point 200rpm or so at a time until it gets better.
Old Jul 29, 2010 | 06:06 AM
arc_55's Avatar
1000cc all around , not needed i know. I will try lowering the rpm point and see if i can get it to go away. I will keep this post updated!
thank you
Old Jul 30, 2010 | 02:19 AM
rx72c's Avatar
Top Answer: 1
bring it down to 2500rpm and work on seeing if its a lean or rich misfire
Old Jul 31, 2010 | 10:23 AM
Aaron Cake's Avatar
Engine, Not Motor
Seems to me that with 4 injectors of equal size, %Stage should be 50%.
Old Jul 31, 2010 | 12:03 PM
arc_55's Avatar
Yes the stage percentage is at 50%. I havent had an oppertunity to work with the stage rpm but i will very soon and keep you updated on the results.
thanks guys
Old Aug 1, 2010 | 09:22 PM
bumpstart's Avatar
talking head
leave stage at 50%
bring down the stage threshold to 2500 rpm and see if its worse ( i expect it is as i anticipate its already a rich crossing )
[ you err rich to prove the issue,, not lean ]
if it is worse you can move the stage threshold back to 3000 rpm and then try upping the other flag ( load ) which is factory set to -5 inch HG ( try 2 psi stage )
so that staging occurs at a higher engine load than before to use up the excess stage fuel
it may just be a matter of raising that load threshold,, or sometimes both that and the threshold RPM
( ie , 3500 and 2 psi stage requires much more fuel than the stumbling 3000 , -5 inch HG stage )
Old Jul 25, 2012 | 05:38 PM
coreye1029's Avatar
tryingsomethingnew
VA question to arc
i have the same size injectors and im having the same problem. i know its the staging but my car is untuned, and nobody around here tunes micro. since yours is tuned, i was wondering if i could use your numbers to tune mine.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
lnlreaper
Sep 27, 2015 09:59 AM
