Power gains
Old Jul 21, 2010 | 07:01 PM
GreenMachine's Avatar
Power gains
Hi im going to be rebuilding my 84 GSL-SE this winter and im asking for ideas on how to get power. ive already decided on a streetport anyhing else i could do? The car is completely stock and money is kind of a problem since i just graduated high school but any suggestions will help.
Thanks
Shea
360
Old Jul 22, 2010 | 08:42 PM
canonize-ryda's Avatar
well if moneys an issue i would just use your stock headers and repipe the exhaust from there either useing stock cat or high flow cat(65 bucks) if u even need a cat(depends on ur state emissions) and go with a free flow muff. u will have to use a air pump(bought mine at walmart 15 bucks) came outa a tire pump. and wire it with a rpm activated switch.(i bought a adjustable one for 50 buck on ebay) and i wired it to provid negative to the air pump at 3800 and it switches on to open aux ports.(definetly need the aux ports for high end). high performance carb if it has a carb that is. to open up the power conversion get a lightweight flywheel and a heavy duty clutch. um maybe a hi price sythetic engine oil. i use gtx(tho many have there opinion on what types and kinds). and maybe some one these may help, ngk plugs, 10.2 mm plug wires, shirt shifter, k@n oil filter, air filter, fuel filter. but thats just me.(got a 80 dollar K@n filter for 10 bucks at a garage sale) so i decided i would use them. hopfully i have help ive done all of this and still want to do more.(porting the engine soon myself) good luck with your project
rx7shirley
Sep 2, 2015 02:11 PM
