what wires whould i wire to for a fuel pump shut off switch?
Old Jun 25, 2002 | 10:48 PM
RiceRocket's Avatar
Livin loud like TIMMAAAYY
Exclamation what wires whould i wire to for a fuel pump shut off switch?
i already have a switch that was wired up by my car's previous owner to shut off the injectors, but it can't be good for the pump to build pressur all the way to the injectors. so what is the best wire to put a switch in to shut off the fuel pump?
Old Jun 25, 2002 | 10:57 PM
RETed's Avatar
It doesn't matter - the stock FPR should stabilize the fuel rail pressure anyways to about 35psi.
Look for the main relay on the steering column under the dash.&nbsp Look for the THIN BLACK wire.&nbsp Be careful, as there are black/white and black/yellow wires in there - you want just the plain black one.&nbsp This is the main ground for the relay low-current side of the circuit.&nbsp This enables you to run a small current rated switch.
-Ted
LunchboxSA22
37
Oct 26, 2015 10:53 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
