Need Advice On Breaks Rotors F+R
Old Jul 16, 2010 | 07:57 PM
gio64's Avatar
Hi everyone.
This might have been beaten down already and I apologize, but when I do searches I only get stuff that has nothing to do with it.
I need to buy rotors and pads on the 4 corners. Beside straight replacement, is there anything you can suggest, drilled (or slotted and drilled) that have an acceptable quality and won't cost me an arm and a leg?
Also, where to buy would be great (online of course).
Keep in mind I am in Canada.
Thank you and sorry for a probably repeat thread, but I have looked, I don't see the info I need.
Old Jul 16, 2010 | 08:02 PM
Warpaint_88's Avatar
Darkside Performance
Pettit racing has a pretty good set that comes with rotors,pads, lines and what not. Its quality, and a decent price.
Old Jul 16, 2010 | 08:40 PM
Check out the Tire Rack. We recently installed a set of Power Slot Rotors on my brother's FD (along with a set of EBC Greens from another site) and he's been very happy with their performance.
Old Jul 16, 2010 | 08:46 PM
ErnieT's Avatar
Living life 9 seconds at a time
I know Im not the road race king lol, but when I went to summit point a few times, everyone there said stock rotors were the strongest. I had a set of cross drilled crack on me as did another friend of mine. If its a street car, Im sure anything would work well.
Old Jul 16, 2010 | 09:33 PM
IRPerformance's Avatar
Sponsor
We offer a brake kit that consists of your choice slotted, drilled, or plain rotors, performance street pads, dot approved stainless brake hoses, and high temp brake fluid. It is an affordable alternative to a big brake kit and works great for both street and moderate track use. I can customize the kit to your needs. Price is $499. I can also get anything tire rack has.
Old Jul 17, 2010 | 08:36 AM
gio64's Avatar
Thank You
Thank you boys, I am looking at options and suggestions.
Some of yours seem to meet my expectations in terms of costs. I did not mention it, but my car is a street car, no track for me (at least for the time being).
Also, sorry for putting the thread in the wrong place (for the admins).
Old Jul 17, 2010 | 08:40 AM
Mahjik's Avatar
Mr. Links
For your needs, grab the kit from here:
http://turboimport.com/catalog/rx7.htm
$439.95 USD for rotors, pads, lines.
Old Jul 17, 2010 | 03:13 PM
Josh18_2k's Avatar
stock is best. only reason to spend money on rotors (other than a big brake kit) is for 2-piece (huge weight savings).
you dont need holes or slots or any of that crap. if the rotors crack from hard driving, get some brake ducting.
Old Jul 29, 2010 | 03:16 PM
chazly413's Avatar
Caution** Engine punches
This, this, this. Stock rotors work fine for everything (also cheap as hell! )
Old Dec 27, 2012 | 10:51 AM
Tem120's Avatar
I got a question , I drive my car kind of hard . My brakes are going . My car CAME WITH , Slotted / drilled rotors .
the front rotors are gone , but hte rears look new . Since the rears dont take asmuch abuse as the fronts would it be ok to just get them resurfaced . rather hten replacing them or are the rears at risk of cracking during hard driving like the fronts ? since they are both drilled and slotted
Old Dec 27, 2012 | 12:48 PM
eage8's Avatar
1308ccs of awesome
If they crack, replace them. It's not that big of a deal, just check them every so often.
I wouldn't even bother getting them resurfaced...
Old Dec 27, 2012 | 12:51 PM
Tem120's Avatar
Ok . I do check them often
Old Dec 27, 2012 | 01:48 PM
RENESISFD's Avatar
Wastegate John
Depending on how deep the gouges are I would get them resurfaced or replace them.
The rears are not at nearly the same risk of cracking as the fronts.
The1Sun
Sep 15, 2015 04:45 PM
Frox
Sep 8, 2015 08:36 AM
risingsunroof82
Sep 7, 2015 01:11 PM
