Power FC Wide band on Power FC??
Old Jul 12, 2010 | 08:18 PM
FDKayzer's Avatar
Hi, I own a PLX devices SM-AFR and I want to know if I could use the WB output for the pfc unit?
Old Jul 12, 2010 | 08:53 PM
ttmott's Avatar
Nope - you need to use the narrow band output to PFC terminal 3c. The PFC would not interpret the wide band output correctly. I have the wide band output going to my data logger (DataLogIt).
Old Jul 12, 2010 | 09:50 PM
FDKayzer's Avatar
mm ok! thanks.
I don't have a datalogit but it's on my "to buy shortly" list.
Old Jul 13, 2010 | 10:31 AM
cewrx7r1's Avatar
Eye In The Sky
The stock FD O2 unit is a narrow band and puts out 0-1 V.
A WB goes up to 5 V.
The PLX has both WB and NB.
You have to understand what car electronics they do and need to become an experienced car person.
Old Jul 13, 2010 | 03:21 PM
FDKayzer's Avatar
I know that nb is 0-1v and wb is linear 0-5v but I didn't know if the power fc could calculate more efficiently with a wideband than with a stock O2 (nb).
Yes there is so much to learn (especialy with rotaries) I read a LOT but I didn't found everything yet to become a experienced enough to "safetune" my car myself.
Like I said, I am about to buy a datalogit but I don't know where to start.
I recently bought a new power fc of last generation and running on base maps that I found way too lean (may the little mods I made don't fit the base maps : non-seq, D-throttle removal, throttlebody porting, intake, intercooler, downpipe, mid-pipe, stock muffler that is about to blow open like a banana, FPR, fuel pump resistor bypassed (had stumbling at low rpm).
The gauge indicates 12-13 afr almost all the way up from 4k rpm, tried to increase the fuel pressure with no significant results.
All this with only 6-7psi (man. boost controller fully opened) I don't even want to try at 10psi.
I need a place to start from, and a little coaching or a working method to stay safe while tuning. Like I said I don't want my car to be perfectly tuned, just safe.
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
s2kguy17
Rotary Drag Racing
Sep 15, 2015 03:05 PM
Shainiac
Sep 3, 2015 10:08 AM
