Super AFC Area is for discussing the Apexi Super AFC
Super AFC Maximum injectors for SAFC??
Old Jul 12, 2010 | 06:56 PM
NI_Racing's Avatar
Racer
I have a SAFC installed in my S4, and im about to finish my 6 port turbo. I have 4 550cc injectors im planning on using, and im sure that the SAFC would be able to control them, but in case i decide to go with bigger injectors in the future. What is the max injector that the SAFC can successfully control?
Old Oct 16, 2011 | 10:56 AM
Sgtbaker's Avatar
Rotorhead
Does anyone know about this? I was about to pick up some 2000cc just cuz they are sooo cheap. I know its totally unnecessary on my NA but I plan on going turbo by next years SS
Old Oct 16, 2011 | 06:42 PM
Sgtbaker's Avatar
Rotorhead
Nvm found ou the answer.
Old Feb 20, 2012 | 09:40 PM
RexRyder's Avatar
So what's the answer
Old Apr 19, 2012 | 08:42 AM
sLiCk WiLlIe's Avatar
This turbo?
Veteran: Marine Corp
^^^ what he said!
Old Apr 19, 2012 | 09:12 AM
dakota's rx7's Avatar
well the safc can only +/- so much fuel so i would have to say it depends on your fuel air ratio when you get the car running, and start boosting on the car. so to say a max injector it could handle i would say it would be unlimited because of this- i could have a big turbo street port engine with 2000cc injectors and im running -15% on the safc and seeing 13 afr. or i could have this a small turbo with 550cc injectors and running the injectors at -15% on the safc and running 13 afr. its still the same value but just different out puts of horsepower. im no expert but thats what i understand. i hope my advice helps a little and someone may correct me if i am wrong with my thinking
Old Apr 19, 2012 | 02:29 PM
flaco's Avatar
yes you are right.
i
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
