Left hand bends make it cut out
Old Jul 9, 2010 | 01:59 PM
kbjrx7@gmail.com's Avatar
Thumbs up Left hand bends make it cut out
91 Convertible cuts out on left hand turns? Cuts out like the key is turned off not like it has run out of gas ( no spluttering) Only cuts out when I'm pulling some Gs (not when maneuvering) so I don't think it a wiring issue in the steering column. Has any one any ideas on where to look first?
Old Jul 9, 2010 | 02:46 PM
RotaryRocket88's Avatar
Top Down, Boost Up
From the FAQ:
My engine cuts out when turning, but there is plenty of gas... whats wrong?
Fuel tank sock is dirty and needs to be cleaned or replaced, and or the baffles in the fuel tank are rusted away.
Old Jul 9, 2010 | 02:51 PM
Go48's Avatar
Do a search for fuel sock or fuel filter. Generally, one cause of this problem has been reported to be partially clogged fuel socks. The fuel sock is attached to the bottom of the fuel pump located in the gas tank. You will need to remove the fuel pump and replace the sock. You can get get a replacement sock from a dealer or MazdaTrix.com.
Get a copy of the factory service manual if you don't have one.
http://wright-here.net/cars/rx7/manuals.html
Old Jul 9, 2010 | 03:03 PM
funkjaw's Avatar
Check the main fuse under the hood to be sure it isn't that. I had a similar problem; my car would cut out during drifting and hard G's. Turned out the main fuse was loose.
Queppa
Nov 18, 2024 03:47 AM
astrum
24
Nov 15, 2017 08:44 AM
Samsquanch
Sep 8, 2015 04:51 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Machupicchu
Aug 17, 2015 08:27 PM
