Turbo choice help please
Old Jul 7, 2010 | 02:59 AM
McCarthy's Avatar
Hey people, i have moved this into here as i got no responce from the tech forum
Righty ho then The senario: 20B, Extended street port, use of car .... no idea yet. Basically i want to build this with a turbo that will let me use the full potential of the engine.... Anyone using the below or any other suggestions would be awsome, any ideas on power/response would be great too
my first thoughts are:
Turbonetics Mid Frame - 76mm compwheel/ 1.14 0r 1.27 A/R turbine
78mm compwheel/ 1.14 or 1.27 A/R turbine
Turbinetics Y2K - 80mm comp wheel but only .96 A/R
Thing that worries me on this one is that its recommended for high boost at 2 bar/30 psi don't really want to run that high?
Or the garrett route
GT4202R 75mm comp with various A/R from 1.01 to 1.28
Any thought sfrom you guys?
Old Jul 7, 2010 | 06:06 AM
Banzai-Racing's Avatar
Rotary Specialists
I run the GT4202R (GT42RS) it has 102mm comp wheel w/ 53 trim (74.7mm inducer) with the TiAL V-band SS housing http://banzai-racing.com/store/Garrett_GT4294R.html
It is a great turbo, spools very nice. We currently have it tuned to 529rwhp @ 12psi, this is just the initial post break in tuning. The entire project and dyno charts can be seen here http://banzai-racing.com/20B_modifications1.htm
Also have a build thread on the forum https://www.rx7club.com/banzai-racing-305/banzai-racing-20b-gt42rs-93-fd-859856/
Old Jul 7, 2010 | 08:56 AM
calculon's Avatar
On flats
Banzai,
You by chance logging EGT and/or EBP? What do you plan to rev to?
Old Jul 7, 2010 | 09:14 AM
Rotary Specialists
I do log and graph the EGT's while tuning, I do not save them though. The engine is happy reving to 8k, may take it to 8500 on the dyno, put it is not like I spend a lot of time in that range on the street.
Old Jul 21, 2010 | 04:01 AM
hmm20b's Avatar
I have a gt42r with a 1.15 hotside 20b extend port in a FD @ 600 rwhp/15psi with meth inj. Turbo suits the 20b torque well.. pulls v strong after 4k rpm and seems not to have any restriction at this boost (ie, wants to keep going). If boost was to come in any earlier, i'ld have too many traction issues.. Pulls consistantly to red-line and spends entire 3rd gear on the verge of losing traction... combined with the 20b's torque, it delivers a fairly linear power curve.
Old Jul 21, 2010 | 08:19 AM
calculon's Avatar
On flats
If you wouldn't mind sharing some logs, maybe in your build thread if you feel that more appropriate, I'm sure I wouldn't be the only one that'd greatly appreciate it.
Old Jul 21, 2010 | 11:57 PM
Valley3's Avatar
Chewing on Tarantula
True story...
Feffman
Midwest RX-7 Forum
Sep 1, 2015 07:30 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
