91 Twin TPS setting
Old Jul 3, 2010 | 09:39 PM
kbjrx7@gmail.com's Avatar
91 Twin TPS setting
trying to get info on setting the twin TPS on a 91 which I think maybe the cause of the rough idle and running on my rebuilt engine. Also put a fuel pump form my dead 87 coupe into it last week so I'm getting a fuel pressure gauge tomorrow to check that is up to specs.
Old Jul 4, 2010 | 10:38 AM
Aaron Cake's Avatar
Engine, Not Motor
Set the narrow range TPS in the same way as the S4 TPS is set. The full range TPS is "self setting".
Old Jul 9, 2010 | 01:46 PM
Thumbs up New problem
Hooked up the test lights. Hooked up the ground wire. Can hear the solenoids clicking as I move the throttle but can't get the test lights to light at all unless I check them on the battery. Never came across this one before... ..... any ideas
Adjusted the tps by the suck it and see method and got it running smooth but not perfect so thanks for you post Aaron
Old Jul 10, 2010 | 10:47 AM
Aaron Cake's Avatar
Engine, Not Motor
Don't use a test light. Use the procedure in the Haynes manual to adjust the TPS to 1K resistance using an ohmmeter.
Old Jul 24, 2010 | 09:11 PM
DrifterX's Avatar
yup always thought the test light was right, turns out when i adjusted it using a multimeter what the test light was telling me was way off.
befarrer
Microtech
Aug 22, 2015 05:52 PM
