Wiring a Fan... 2x Checking
Old Jun 24, 2002 | 11:47 PM
Liquid Anarchy's Avatar
We come with the Hardcore
Ok... A relay has 4 connections. 1's the power, 1's where the power will go, 1's a ground, and the other is a "trigger"... here we go...
To wire a fan, I'd think you'd need a temp switch, and 2 30A relays.
Relay #1 is for the temp switch
Constant = Battery
Ground... = Ground
Power WILL go = Temp Switch
Trigger = 12v+ Acc wire.
Relay #2 is for the fan
Constant = Battery
Ground... = Ground again
Power WILL go = Fan
Trigger = Temp Switch & The A/C Fan switch
Does that sound right? ( It looks a lot better on paper... trust me ) Sorry I don't know terms.
Old Jun 24, 2002 | 11:49 PM
Oh yeah... should I just fuse the constant powers? Or is there something else I should fuse???
Old Jun 24, 2002 | 11:59 PM
NZConvertible's Avatar
I'm a boost creep...
Just one relay and one fuse, like this:
Old Jun 25, 2002 | 12:08 AM
But what about having it on when the A/C is on?
Old Jun 25, 2002 | 12:09 AM
or, just add the A/C Switch to the "Switched Ignition" Prong.... gotcha
Old Jun 25, 2002 | 12:15 AM
Sorry, missed the bit about the A/C. Put the temp switch on the other side of the relay (the "switched ignition" side), and run a wire from the A/C clutch wire to the same terminal on the realy, i.e. in parallel with the temp switch.
Old Jun 25, 2002 | 12:16 AM
Ok... I'm confused... there are 3 +'s going into the relay??? I'm no Einstein, but I used to be pretty heavy into car audio... and that makes 0 sense to me. Sorry.
*500th post BTW
Old Jun 25, 2002 | 12:22 AM
Here's what I want to accomplish.
I want the Fan to turn on when the temp is too high, or the A/C decides to turn it on. Also, I want it to turn off when I turn off the ignition. That's it.
What do I need to wire?
Refer to it by these letters please.... to make it simple fer' me.
Old Jun 25, 2002 | 05:01 PM
Your relay is basically the same as the one in my diagram, but a lot of automotive relays have the 5th pin I show. You don't need it so don't worry about it.
So it'll be like this:
A - Two wires on this terminal; one that goes from a switched ignition source (enables system only when ignition's on) to the temp switch, then to the relay. the other wire goes from the A/C compressor clutch wire (tap into it) straight to the terminal.
B - From the battery via a 20A fuse.
C - Earth
D - Fan motor.
I'll try to sort out a diagram.
Old Jun 26, 2002 | 06:44 AM
SureShot's Avatar
Seduced by the DARK SIDE
OR - you can just buy the control from Pep Boys with the diodes for manual override and A/C override already there..
Bill
Old Jun 27, 2002 | 04:31 PM
OK, here's the new wiring diagram for operating the fan with the A/C.
Old Jun 27, 2002 | 06:31 PM
Shouldn't I use a relay for the switched ignition to the temp. sensor? Or does it have a low draw? ( Looks like I got it right tho! )
Old Jun 27, 2002 | 06:36 PM
Very low, 0.1-0.2A.
Boriquaguerrero
20
Apr 22, 2019 01:15 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
fastsaab
Aug 19, 2015 11:42 AM
