8psi to much back presure?
Old Jun 24, 2002 | 10:35 PM
RX-8's Avatar
I can't get a clear anwser on this. It was measured at the downpipe. My car is stock except for a downpipe please help!
Old Jun 24, 2002 | 10:47 PM
KevinK2's Avatar
not too much if u just putt around as some do, and rarely use max power.
if u want more usable power, start the upgrades. search for mods, upgrades, etc.
Old Jun 24, 2002 | 11:56 PM
95R2-89TII Ground Zero's Avatar
Banned
Yeah, I agree. I would say that if you are just tooling around you should be okay.
Old Jun 25, 2002 | 12:05 AM
RX-8's Avatar
I was told by a shop that this is way to high for an fd, is this true? Do i need to replace my cat? Thats what they were saying.
Old Jun 25, 2002 | 12:10 AM
Mahjik's Avatar
Mr. Links
What's the problem that you are experiencing which the shop thinks you need to replace your cat for (or that they were checking the back pressure)?
If you take a look at this thread:
https://www.rx7club.com/forum/showth...=back+pressure
7 lbs of back pressure with a high flo cat, so 8 lbs with the stock cat doesn't sound like it's clogged...
Old Jun 25, 2002 | 12:15 AM
RX-8's Avatar
Let me explain in greater detail. I have alot of hissing coming from my engine bay and my downpipe glows on the part that connects to the engine. So I was thinking that the back pressure from my "clogged" cat could be the reason for the glowing downpipe and possible the vaccume hoses hissing possible because they have blow off. Rotary Gods does this make since? As is it turns out the shop that told me about my clogged cat is not reputable, thanks.
Old Jun 25, 2002 | 12:21 AM
Mahjik's Avatar
Mr. Links
The upper part of the downpipe can/will glow redish orange due to the heat sometimes (after some spirited driving or something). That's pretty typical.
However, the hissing sound... When you do hear it?
Old Jun 25, 2002 | 12:43 AM
RX-8's Avatar
When ever i touch the accel petal. The harder i press the slower the acceleration. Weird huh? By the way thanks for the responce, you saved me 450 bucks on a new cat!!
Old Jun 25, 2002 | 07:37 AM
Mahjik's Avatar
Mr. Links
Do you have a boost gauge installed?
If not, this is the *ideal* time to get one. If you do, what boost pattern are you seeing?
Old Jun 25, 2002 | 09:52 AM
RX-8's Avatar
12-10 is what my mechanic said. i think i am going to take the intae pleneum off and look for loose vaccume hoses and buy a boost gauge today.
Old Jun 25, 2002 | 09:58 AM
Mahjik's Avatar
Mr. Links
12-10 is what my mechanic said. i think i am going to take the intae pleneum off and look for loose vaccume hoses.
If you are going to go under the hood yourself, you may as well purchase a boost gauge and hook it up.
Just pick up a cheap one. You won't be staring at it every day, but they REALLY help in situations like these.
http://66.216.67.51/product.asp?0=212&1=270&3=388
12-10 what? Is that suppose to be your boost pattern? Did your mechanic happen to mention what your vacuum was?
Old Jun 25, 2002 | 10:25 AM
RX-8's Avatar
No he didn't mention my vaccume. It was a Mazduh mechanic (idiot). To make a long story short I buy a new engine from mazda and have them install it and it runs 100 times worse then the original engine! Sorry had to vent. The boost pattern the mechanic said was 12 and slowley pull back to 10. But who knows.
Old Jun 25, 2002 | 10:41 AM
Mahjik's Avatar
Mr. Links
lol, ok... There are some good Mazda mechanics that do know how to work on the cars, however, finding them is harder than finding that needle in the haystack.
Your best bet at this point is to get a boost gauge, hook it up and check the following things:
1. Vacuum at ildle (idle should be around 750-800 rpms)
2. Do the boost test: http://www.scuderiaciriani.com/rx7/boost_test.html
Once you have those results, it will be much easier to troubleshoot what is going on. Good luck!
Old Jun 25, 2002 | 10:45 AM
RX-8's Avatar
Thanks!!
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
