Full Fluid Change / Flush
Old Jun 24, 2010 | 08:47 PM
r074r'/ |\|00B
I am going to be a new owner soon, and want to do a complete fluid drain/fill/flush so I will have all fresh fluids. I've done my best at using the search buton and would like to make sure I have everything listed written down correctly.
Engine:
5 Quarts
20W-50 (summer) or 10W-30 (winter)
Mobil 1 / Castrol GTX
every 3k miles or less
Transmission:
2.6 Quarts
75w-90
Amsoil / Redline / Royal Purple
every 20k miles or less
Differential:
1.4 Quarts
75w-90
Power Steering Fluid:
1 Quart
Dexron II or M-III
every 10k miles or less
Brake Fluid:
1 Liter
ATE Super Blue Racing Brake Fluid
Every spring
Coolant:
1 Gal Prestone (green)
2 Gal Distilled Water
Every spring
How'd I do?
Old Jun 25, 2010 | 03:22 PM
funkjaw's Avatar
Royal Purple diff fluid typically comes with the LSD additive that you may or may not need. I would look into that.
Old Jun 26, 2010 | 05:34 PM
r074r'/ |\|00B
I decided to go with the NEO oil for tranny & diff.
http://www.4wheelparts.com/1-QT-NEO-...t_pn=NEO7590HD
highspeedrider
Aug 19, 2015 03:44 AM
