Rx7 s4 N/A Computer with a TII Engine
Old Jun 21, 2010 | 09:02 PM
stuwk1's Avatar
If I were to keep my stock ECU in my N/A s4 what are all of the electronic components that I would need to swap the TII motor in there and it run correctly. Or would it be cheaper and worth the money to buy a used turbo ecu.
Old Jun 21, 2010 | 09:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You should never run a turbo engine with NA ECU and sensors. They're not meant to see boost, so when the turbo spools, you'll have almost no fuel/timing management to compensate. In other words, you'll just blow an engine by cutting corners. Click the link in my sig. to read up on how to properly swap in a TII engine.
Old Jun 21, 2010 | 11:22 PM
stuwk1's Avatar
O shiz you da best thanks
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
