headlights wont come turn on
Old Jun 16, 2010 | 03:48 AM
lm38330's Avatar
well im currently building my ls1 fc.i just did the wiring and i notived everything turns on except my headlights.everything is connected.my switch is good since my dash lights up and all.is there a headlamp relay? anyone ran into this?
thanks
Old Jun 29, 2010 | 01:23 AM
midnightbluefc's Avatar
your headlights don't work do they at least flip up? check the fuses by the drivers strut tower...
Old Jul 18, 2010 | 08:28 AM
daveditch's Avatar
Headlights will not work
I have a similar problem with my 82 RX7. Initially the headlights worked, then only the high beams worked. Now nothing works. I suspect the steering column switch but I would appreciate advice. I have checked the fusable links on the strut tower - they were ok
Thanks
Old Jul 18, 2010 | 09:57 AM
LIONEL88RX7's Avatar
there is a relay behind the headlight on the passenger side in front of the air box and also cheak the wink switch above the headlight switch could be the problem
Old Jul 18, 2010 | 10:09 PM
rxtasy3's Avatar
and sometimes it's just that the contacts in the switch needs cleaning.
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
