convertible top problem...
Old Jun 14, 2010 | 06:07 PM
WCP_RX7's Avatar
I have a 1988 RX7 convertible and the top won't go down? the switch on the dash makes the electronic module in the back beep steady then it goes to a continuous tone... any suggestions?
Winston
Old Jun 14, 2010 | 08:11 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Is the e-brake on? The top won't work if the e-brake it not engaged.
Old Jun 15, 2010 | 10:37 AM
WCP_RX7's Avatar
Thanks for the reply, yep the e brake is engaged... should have mentioned that in my first post...
Winston
Old Jun 15, 2010 | 10:40 AM
WCP_RX7's Avatar
Is there anyway to bypass the switch and manually lower the roof?
Old Jun 15, 2010 | 12:50 PM
Top Down, Boost Up
Yes, the top can be manually raised/lowered. Here's a link with info from the series 5 owner's manual: http://www.cabrio7.org/rx7man1.html.
Old Feb 5, 2013 | 01:20 PM
hartjdh's Avatar
That link didnt work for manual over ride is there any other one? my top is stuck down and unfortunately i lost my indoor storage and its snowing here cant leave it outside with the top down please help!!
Old Feb 5, 2013 | 05:52 PM
Top Down, Boost Up
This thread is 2.5 years old, and that link has died.
Post #6: https://www.rx7club.com/2nd-generati.../#post11293362
Donald Hampton
16
Nov 23, 2022 06:38 PM
