porting question
Old Jun 13, 2010 | 03:05 PM
dkaszak88's Avatar
NJ porting question
so when you portout a 6 port what ports do u open up? primaries secondaries or auxillary? i cant seem to figure it out im looking into eithing doing as big a street port as possibl or a hand alf bridge or something its for a street car. i just cant seemto figure it out
Old Jun 14, 2010 | 09:14 AM
Aaron Cake's Avatar
Engine, Not Motor
ANY porting you do on the 6 port block will reduce low end torque. The 6 port blocks already have HUGE ports.
Limit your porting to the primary ports by moving them up a little. Don't move them out towards the rotor housing.
Move the exhaust ports up a few MM and widen them a few MM. Remove the diffuser.
Move the aux port out towards the rotor housing a little.
A good port template is the Mazdatrix 6 port template.
hotshot2014
Jul 18, 2017 02:30 PM
