question why does?
Old Jun 10, 2010 | 09:05 PM
rotaryking88's Avatar
Question question why does?
i just got a N/A 86 gxl motor completely stock noticed there fluid in the combustion chamber can anyone give me reason why this may be?
Old Jun 10, 2010 | 11:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Well, what kind of fluid is it? Coolant? Oil? Sometimes oil can be used for long term storage, or it could mean the oil control rings failed before the engine was pulled. Coolant would mean failed seals and rusted housings/irons/rotors.
Old Jun 11, 2010 | 02:51 AM
20bseven's Avatar
yep fluid in the chamber is never a good sign.
Old Jun 11, 2010 | 07:22 AM
from what i was told it's coolant
Old Jun 11, 2010 | 09:52 AM
Mahjik's Avatar
Mr. Links
Coolant o-rings have failed. This could be from a few reasons:
1. Corrosion in the coolant passages
2. Warped rotor housings from overheating
Either way, it's a rebuild. The main difference will be what engine parts need to be replaced during the rebuild. You won't know that until the engine is disassembled.
Old Jun 11, 2010 | 10:33 AM
Kentetsu's Avatar
Before you fall too deeply into despair, read this thread: https://www.rx7club.com/1st-gen-archive-71/engine-coolant-seal-repair-maybe-750774/
14,000 miles and two years later, still going strong.
Old Jun 11, 2010 | 10:58 AM
89fc3sgtu's Avatar
boosted fc
go to rotaryressuerection.com in the teck section they have a write up for an easy fix and they say it works
Old Jun 11, 2010 | 11:01 AM
Top Down, Boost Up
If the engine has been sitting with coolant in the chambers, it has most likely rusted to the point of being useless. The irons and rotors will not be happy to sit in a pool of coolant. Inspect it through the exhaust ports with a light, see if it turns over by hand, and test compression.
Old Jun 11, 2010 | 02:39 PM
what are the best o ring a person can get
Old Jun 12, 2010 | 06:21 PM
thejallenator's Avatar
oem. get em from mazdatrix or atkins or similar. but you better be ready for a task when it comes to rebuilding. youre prolly gunne need to replace other stuff. prolly will be easier for a tii swap
Old Jun 13, 2010 | 07:37 PM
you really think so more or less how long will a rebuild take if i have all parts ready for the rebuild
Old Jun 13, 2010 | 07:47 PM
rxtasy3's Avatar
the rebuild doesn't take long at all. it's the tear down, checking to see what parts will need replacing, and the cleaning and prep work needed that's time consuming. hard to give an actual time period cause if ur doing it urself, it'll depend on just how much time u will have to spend working on it between ur job and other things like can throw at u. but i'd say a week or two at least. then u have to take into consideration problems u may run into during the process like waiting on parts to arrive or broken bolts, etc. not to mention if u want to get any porting done.
Old Jun 13, 2010 | 07:56 PM
sound good im on a 4 month time period well im more then likely going to need seals o rings maybe rotors and housing know of anyone they maybe selling housing and or rotors and how much do they go for both used and new
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
