refinish s4 tail lights black piece?
Old Jun 9, 2010 | 11:36 AM
driftxsequence's Avatar
Rotisserie Engine
My tail lights are in decent condition, i'm too poor to buy a set of S5's(oh i would love to...)
SO. my tail light black surrounding piece is kind of faded, and is almost gray. i saw a 3M refinishing kit for 30$ to shine up lenses but i wasnt sure if it was the case for the outer piece also. its weird because when it is wet, it turns nice and black again but when dry it is nasty and gray.
i searched for "refinishing" and such and found nothing so that is why i am asking here..
im a little afraid, the S4 light are growing on me...as much as i hated them before actually owning the car
please help me make my car pretty! and if you guys point me in the right direction, i'll try to do a nice write up with pictures!
Old Jun 9, 2010 | 11:53 AM
Rob XX 7's Avatar
FC guy
I have had great success sanding and epoxy priming the housings, then sanding that and spraying black paint on the housings- comes out great.
Before you do it polish the lenses out really well and you will end up with a set of better then new lights
Old Jun 9, 2010 | 12:12 PM
need RX7's Avatar
Listen to King Diamond.
I sanded mine down to smooth out the surface, since they were really faded and took on a textured finish (I believe I started with a random old coarse sanding block I had lying around, then 400, then 600, then some really fine stuff I had left over from my model building days), then sprayed rattle can clear coat on them and buffed that. Looks really good, and is the only 'paintless' S4 tail restoration I've seen.
The result (before and after):
Old Jun 9, 2010 | 12:19 PM
Rob XX 7's Avatar
FC guy
how can you call them paintless if you rattle canned them?
Old Jun 9, 2010 | 12:42 PM
Rotisserie Engine
that is exactly how mine look. so i just need to sand them down....and rob, clear coat sounds a bit easier to work with over black paint. less chance for bleeding onto the lenses.
since this is plastic, what kind of paint should i be using? polycarbonate? stuff from home depot? i've never done much painting except for my RC cars where you paint the inside of the body so when you crash it doesnt come off on the outside :P
Old Jun 9, 2010 | 01:59 PM
need RX7's Avatar
AL
I only sprayed them with clear, so technically the original finish is showing through... I guess.
Really, painting them would probably be easier .
Old Jun 9, 2010 | 03:13 PM
Rob XX 7's Avatar
FC guy
the black will NOT bleed through, I have done 4 sets of those lights- trust me it wont bleed through. If you are going to spray clear just spray black
Old Jun 15, 2010 | 02:39 AM
w.sen's Avatar
In a Bucket
I took masking tape to the lenses and hit it with black... looks very fresh... I even went and tinted the lenses for a blacked out look.. Looked good but decieded against it. For safety reasons.
Old Jun 15, 2010 | 07:19 AM
Rob XX 7's Avatar
FC guy
because you cant spray straight black over the lenses and have it come out good, you have to spray something that is translucent, a good rattle can product is VHT niteshades
Old Jun 15, 2010 | 05:31 PM
FirebirdSlayer666's Avatar
Famous Taillights
^^^Rustoleum also has a Lense tint spray. I'm curious how it is compared to the Niteshades since that's all I've ever used.
Old Jun 15, 2010 | 07:19 PM
Spirit-RE's Avatar
I buffed my centerpiece with 3M's kit. It was 'moderately' faded, not gray, but not black. It made it shine, but you can still see the tiny groves/cracks if you look really hard...
Old Jun 16, 2010 | 03:55 PM
w.sen's Avatar
In a Bucket
My old boss gave me a huge roll of tint.. But the problem was every 6 inches it was creased. I figured I can try to black out my my tails to see ow it comes out.. Looked really hot. But durring the day the brake lights were very weak. And ripped off the tint..
I myself would never use the spray can of tint just because once you spray it its there and not coming off easily. Thas just me tho.
Old Jun 16, 2010 | 04:13 PM
Rob XX 7's Avatar
FC guy
use the VHT from the rear and it looks great, you can do that pretty easily to s4's, looks very stockish
Old Jun 16, 2010 | 06:48 PM
Damzil's Avatar
E-peen
I know a few members who have baked their s4 tail lights. Something about heating it to separate the moldings, then they look like ridiculously bright s5 tail lights.
Old Jun 16, 2010 | 08:06 PM
city's Avatar
slide or die
sand it paint it clear it and it will be good
Old Jun 16, 2010 | 08:20 PM
Famous Taillights
Doesn't work that way. The lenses are apart of black outer piece and the rear housing seperates from that. I would love to replicate these someday
Old Jun 16, 2010 | 08:32 PM
Rob XX 7's Avatar
FC guy
my original s4 lights I polished the lenses, then VHT from the backside, and refinished the black, they looked like they came from factory, not enough tint to be bothered or not be safe and just enough to be custom
Old Jun 17, 2010 | 09:05 AM
Rotisserie Engine
WOW...those look bad ***!!
Old Jun 23, 2010 | 08:54 AM
Rotisserie Engine
Does anyone have any more info on the red and white only s4 tails? those would make rocking s4 lights awesome!
Old Jul 1, 2010 | 11:51 AM
SouthSideSlider's Avatar
whats a Turbo V?
on my first set of lights i did(made S4s into 10AEs) i used a gloss black paint and painted where the bulb sat but left the lens factory color it looked realy good
Old Jul 1, 2010 | 12:41 PM
Hypertek's Avatar
Slowpoke
get em glossy looks good
Old Jul 1, 2010 | 12:51 PM
waldog's Avatar
Whipping thru traffic.
Seeing those makes me wanna keep my S4 lights on my GXL.
Old Jul 1, 2010 | 01:23 PM
Hypertek's Avatar
Slowpoke
yeah they look sexy when in they are in good condition and polished to a mad shine
s5 wouldnt look good on that car imo
Old Jul 1, 2010 | 02:01 PM
Rob XX 7's Avatar
FC guy
Old Jul 1, 2010 | 03:30 PM
Rotisserie Engine
how high of a grit sand paper do you reccomend to go to? 2000 grit? also how do you pull them out? i pulled down the carpet to try and get a better look but i only saw one screw
