transmission question
Old Jun 7, 2010 | 09:48 PM
Roxy's daddy's Avatar
VA transmission question
is there a difference between a flywheel and pressure plate on an 87 n/a and a 89 n/a engine? because i did a swap and my clutch isn't disengaging i didn't know if i had to get a new pressure plate or if it would be ok to use the old one from the 87 engine
Old Jun 7, 2010 | 11:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
S4 and S5 NA clutch kits are the same. The flywheels are the same diameter, but the built-in counterweights (in manual flywheels) are different. The flywheel should be the same series as the rotors to avoid serious balance issues.
Old Jun 8, 2010 | 12:48 PM
ok so the pressure plate should go on with no problems? awesome so is there a specific way to mount the pressure plate onto the flywheel? i think i may have it wrong is y my clutch wont disengage, thanks for ur help
Old Jun 9, 2010 | 08:39 AM
Aaron Cake's Avatar
Engine, Not Motor
The pressure plate mounts the way it fits. I think it will fit in several orientations, none of which will be an issue.
If your clutch won't disengage, you may have the clutch disc backwards. Or it could be a simple hydraulic problem, or a clutch fork that has popped off the pivot.
Old Jun 9, 2010 | 11:22 AM
ok cool thanks ill try bleeding it somemore and if that dont work then ill drop it and check the throw out bearing
_Tones_
May 25, 2021 05:37 AM
Enzo1944
Sep 6, 2015 08:57 AM
