Uneven idling
Old Jun 5, 2010 | 05:30 PM
magicchef's Avatar
CA Uneven idling
I have a '93 fd w/ '99 turbos, Racing Beat exhaust. Engine replaced 50,000 miles ago. Car generally runs great. When cold the idle alternately runs up and down from about 800 to 1200 rpm until warm, then runs smooth, idling at about 900-1000. Anyone have any thoughts about why this is and how to resolve it? Thanks.
Old Jun 6, 2010 | 03:05 PM
mar3's Avatar
Administrator
Tossing this out there for the 3rdgen guru's after pulling it from the wrong board. I'd have no clue since I'm a 1stgen guy.
Mario III
Old Jun 13, 2010 | 04:28 PM
Josh_rx7turbo_2's Avatar
It's suppose to, that's characteristic of a rotary engine.
Old Jun 13, 2010 | 07:12 PM
Mahjik's Avatar
Mr. Links
Question
Is the airpump installed and working?
Old Jun 14, 2010 | 03:22 PM
datz's Avatar
GNARKILL
i have a similar idle prob, but cant for the life of me beleive mazda would intentionally do that ^
Old Jun 14, 2010 | 03:49 PM
Roto_Racing's Avatar
Roto Racing Development
rotaries ... am i right
its the whole swapping the engine thing if i were you take it to a local dyno and have it tuned. my fc had idleing issues when i first swapped the engine for an 89 n/a took it to a dyno and bam now it purs like a kitten. here it cost $50 for light tuning so its not all that expensive.
Old Jun 15, 2010 | 10:12 AM
Maybe I should clarify, and maybe not assume so much, but on a cold day all three Ffc's I've had over the years would sputter at that rpm range, and once warmed up would fluttter at 700-900 rpm's. I didn't realize it was and fd so maybe there's a difference there? However, my current fc (88 t2) is pretty steady at ~1100 rpm when cold (on a warmer day) and then drops down when it warms up.
I thought that was characteristic of cold start, if not I apologize. Correct me if I'm wrong, but isn't the idle controlled by the TPS/BAC? I think a leaking intake can also cause idle problems.
Old Jun 15, 2010 | 01:52 PM
these engines will sputter in the cold no matter what but when heated up they should stay steady. rough idleing can be caused by bad grounds, tps, egr, bad tuning, light flywheel or clutch, sometimes worn oil, vacuume leak, man so many things. take the time to look over a manual spend a day under your hood, its the best advice i have ever gotten.
good luck
Old Aug 8, 2010 | 10:06 PM
magicchef's Avatar
Goodbye, for now
I have sold my RX7 after 6 years and a new motor. If I ever get another one, I'll be back.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
