PIX installed NPR FMIC
Old Jun 23, 2002 | 09:28 PM
vosko's Avatar
Just Call Me Terminator!
my friend and i installed my NPR FMIC courtesy of Greg just gotta fab up piping after i drop in the engine. also need to make brackets for my radiator. anyway here are pix
Old Jun 23, 2002 | 09:30 PM
vosko's Avatar
Old Jun 23, 2002 | 09:33 PM
jmseven's Avatar
Asset is Wealth
very dark.....cant see anything.
TonyTurboII's Avatar
Glock Lover
Not too long till thats ripped off by some road obstruction.
Old Jun 23, 2002 | 09:36 PM
Greg's Avatar
Good Gawd!!
you guys see my half *** (literally) polishing job
Old Jun 23, 2002 | 09:37 PM
Node's Avatar
thats disgustingly large, you should be ashamed of yourself.
Old Jun 23, 2002 | 09:45 PM
NZConvertible's Avatar
I'm a boost creep...
Actually I can't see a thing! Doesn't your camera have a flash?
Glock Lover
Well said.
Old Jun 23, 2002 | 09:50 PM
vosko's Avatar
umm i can see the pix fine. you need to turn up your brightness. the pix were take at dark. sorry about that. you know me. i like things large and in charge
Old Jun 23, 2002 | 09:53 PM
kabooski's Avatar
Laying Down Rotary Law
dang I hope your going to push 15 PSI
cause that Cooler all the way up there
is going to LAG! if you don't push alot of CFM
I'm putting the same IC where the water overflow
goes
and the Inlets facing up wraping around the Rad/batt
Batt will go in the Back
Yes cutting reguired
Old Jun 23, 2002 | 09:57 PM
vosko's Avatar
i test fitted the IC there but you have to bend and relocate some stuff. i saw how turborotor's greddy 24R intercooler was installed and its in the same spot as mine. we'll see how it works out. i plan on pushing the stock ht-18s to its max. plans are already in the works for a much larger turbo. i still have some tricks up my sleeve
Old Jun 23, 2002 | 10:01 PM
kabooski's Avatar
LoL
Here one of My Mechs work
with a LARGE NPR
You can see the IC routing which I love
Old Jun 23, 2002 | 10:21 PM
vosko's Avatar
wow that pipe routing is NICE. mine will be a little more convaluted. mine will be about the same. just has to go down about 8inches more. shouldn't be that big of a deal. my car looks like a corolla from englishtown now
Old Jun 23, 2002 | 10:33 PM
gz91rx7's Avatar
DAMN THAT IS HUGE!!!!!!!!!
Good job on the corona!!
Old Jun 23, 2002 | 11:03 PM
turboGXL's Avatar
Damn vosko! why didn't you go with the smaller one?! =)
Old Jun 23, 2002 | 11:13 PM
vosko's Avatar
i got that one CHEAP
Old Jun 24, 2002 | 12:08 AM
turboGXL's Avatar
I bet you did!=) Hopefully you've got a BIG enough turbo you won't be experiencing a huge pressure drop.
How's the new engine?
Old Jun 24, 2002 | 01:46 AM
elliegant's Avatar
bigger is better... hehe.... very nice!
Old Jun 24, 2002 | 08:36 AM
bob13bt's Avatar
Fixed the wheelhop
I see a box for a Griffin radiator....is that the $180 one from Summit? (for Ford)
IC looks good. Hopefully not too much lag.
Old Jun 24, 2002 | 09:43 AM
vosko's Avatar
i'm running stock turbo for now. i want to see how well it will do @ high boost. after i break i'm gonna make a custom T04 turbo kit for my car the jspec i got looks to be perfect. its sitting in ATF right now. it has good compression. we'll see how long its gonna last. if this breaks i'll rebuild the other engine and port it etc
Old Jun 24, 2002 | 09:45 AM
vosko's Avatar
yeah that's the chevy radiator from summit. fits almost perfect just have to figure out how to weld brackets to aluminum for it. shouldn't be too hard. i don't think the pressure drop will be that bad on the intercooler. we'll see when i get the whole car running in 2 weeks i hope
Old Jun 24, 2002 | 10:46 AM
HN's Avatar
HN
nice install. as you already know the pressure drop is massive on the stock turbo. just run a 60 and you'll be fine. everybody thinks there is huge lag on that ic but once you go to a bigger turbo you have no problem.
Old Jun 24, 2002 | 12:30 PM
vosko's Avatar
i just want to get my car up and running then start gathering the parts i need. exhaust manifold, turbo, wastegate,bov,boost controller
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
vmerino
Sep 5, 2015 11:26 AM
