stranded!
Old Jun 2, 2010 | 01:45 PM
datz's Avatar
GNARKILL
AZ stranded!
well i seafoamed my 7, rougly 33%in gas, oil, and AWS vacumm line into dynamic chamber. did this then killed the engine a min after seafoming, waited 5-10 mins and now it wont start, will crank(rotate) no start though. i thought the seafoam "flloded" the engine, so removed plugs, EGI fuse, and cranked for 5 seconds at a time untill the battery was dead (about 12 cranks). hopefully after my battery charger does its thing it will start so i can get it out of the middle of my slanted driveway blocking people,and the HOA says no parking on street, so i cant push out of the way.
has anyone had a problem like this with seafoam?
Old Jun 2, 2010 | 03:07 PM
gracer7-rx7's Avatar
needs more track time
From what I have read of other rotary owner's experiences with seafoam, I'd get it out of the engine ASAP. A friend of mine blew his turbo rotary when using sea foam.
The only recommendation I can make is to do a compression test and check the health of the motor.
Old Jun 2, 2010 | 04:32 PM
datz's Avatar
GNARKILL
i changed the oill, the spark plugs are fouled, there is spark through the plug wires on the trailing coil but not the leading. if i get new plugs and wires and put them on a dead coil will it ruin the new plugs and wires? should i get a new ecu and install it? should i get a new coil also?
it was running fine yesterday.
Old Jun 2, 2010 | 04:34 PM
datz's Avatar
GNARKILL
ive heard not to put it in the oil but the gas is ok and havent heard much on putting it through a vacum line
Old Jun 2, 2010 | 04:36 PM
rxtasy3's Avatar
from what i've read about using it is u put it in the gas tank, not the oil. did u do any research first or just hear ppl used it and got some and started pouring it in?
Old Jun 2, 2010 | 06:12 PM
datz's Avatar
GNARKILL
i did some research, not alot. my uncle and several friends use it but they dont know anything about rotorys or have one.
i did a compression check and the numbers were the same as 3 weeks prior, ~87 ~87 ~87, ~87 ~87 ~87.
Old Jun 4, 2010 | 04:44 PM
blackdeath647's Avatar
weak minds wear the crown
one of the times i did the seafoam it fouled my plugs that needed replacing anyways, changed the plugs and it ran.
Old Jun 4, 2010 | 09:23 PM
datz's Avatar
GNARKILL
yup changed the plugs and wires and she started right up.
Old Jun 5, 2010 | 01:19 AM
Kentetsu's Avatar
Yeah, I keep telling people that Seafoam is great for rotaries, but just dump the **** in the tank, keep it out of the oil, and don't try to get fancy by sucking it in through vacuum lines and **** like that.
Old Jun 5, 2010 | 01:46 AM
littlemimus's Avatar
run from thee sandvich!!!
they say to put it in the oil but change it 100 miles after you do. cause it breaks it down.
Old Jun 5, 2010 | 02:12 PM
datz's Avatar
GNARKILL
ive noticed now if im accelerating ~2/3rd throttle in 2nd gear with rpm just passing 3k, if i release the throttle and depress the clutch imediatly the rpms will continue to climb ~500-1000rpm, for a split second, loike i still have the throttle depressed.
has anyone heard, or expierienced anything like this. my guess would be the BAC.
radiantRX-7
18
Sep 15, 2015 07:04 AM
jutny
11
Sep 4, 2004 05:36 AM
ttb
Jun 13, 2004 06:50 PM
