fuel pump not working
Old May 26, 2010 | 01:13 PM
kray2007's Avatar
I just replaced the wiring harness on my non turbo 88 rx7. The fuel pump is not working. I am missing the fuse box cover, so I don't know which fuse is the fuel pump.
The reason for replacing the harness was it burned up. So maybe a fuel shutoff was engaged?
Old May 28, 2010 | 09:05 AM
Aaron Cake's Avatar
Engine, Not Motor
How are you testing the fuel pump? It will only run if the engine is running.
You will find an image of the fuse box cover in the 2nd gen FAQ.
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
