Drifting Discuss Drifting and drifting techniques here.
diy ebreak drift botton 4 a penny
Old May 26, 2010 | 12:35 AM
infected panda's Avatar
no rotor no motor
ok first remove boot that surounds e break handle. then incert a penny. push the penny in as far as you can with your finger. reinstall ebreak boot. should look like this.
and when you want to have the ebreak work pull it out a little. ect. ect.
Old May 26, 2010 | 05:58 PM
lonetlan's Avatar
Too Many Questions
Interesting
Old May 26, 2010 | 06:41 PM
Digi7ech's Avatar
I break Diff mounts
I like having and ebrake for normal parking. I'll stick with my Japan2LA button
Old May 26, 2010 | 10:13 PM
no rotor no motor
still works for regular parking. just pull forward. again poor mans cuctco
Old May 27, 2010 | 01:12 AM
NoPistons!'s Avatar
Tango Down
Your shift boot is nuts.
"boots wit the furrrrrrr*
Think a bottle cap would work?
Old May 27, 2010 | 01:31 AM
Battle Cat's Avatar
Space cadet
tape works just fine
Old May 27, 2010 | 09:08 AM
no rotor no motor
"boots withthe fur " thats a great one. i wanna add some googly eyes. so it will look like a muppet. a dead one.
Old May 27, 2010 | 05:45 PM
Supastar Bruce's Avatar
boom!
Old May 27, 2010 | 06:36 PM
Battle Cat's Avatar
Space cadet
Old May 27, 2010 | 06:40 PM
ashleyanne's Avatar
Dead muppet shift boot? Originality points.
Old May 27, 2010 | 07:48 PM
puhpaper's Avatar
The spelling in this thread is atrocious. Also, this is your e-brake we're talking about. The thing that keeps your car from rolling down a hill when you're not in it. Is this something one really wants to "budget"?
I think you're better off paying the $15 for an e-brake button.
Old May 27, 2010 | 07:58 PM
nightridaz777's Avatar
Welded Ass Hell
might have to put this on the list for things to do once i arrive at the track and b4 i leave the track.
Old May 27, 2010 | 08:14 PM
Battle Cat's Avatar
Space cadet
i got mine in ionized pink
Old May 27, 2010 | 08:49 PM
danegerous's Avatar
it go down in the dm
I got mine in gun powder and dead babies
Old May 27, 2010 | 09:09 PM
no rotor no motor
how did you rid that handle. and penny button does not effect e-break function.
Old May 29, 2010 | 06:21 PM
NoPistons!'s Avatar
Tango Down
That's a hydro handbrake. You bolt the **** down wherever you feel like it, plumb your lines and presto. You have that or any other design or setup you can think of. Good setup keeping both considering you can't jab the brakes and hit the hydro at the same time.
Your write up helped someone! Thank you dude. I'm all for getting the job done for cheaps!
You could just keep a piece of pipe or a block of wood in your car to put under the tires when parked if you're not man enough to pull the handle forward to get the penny off the button
Yes, this is **** someone REALLY wants to "budget". $15 saved to buy smokes and beer to support my rock n roll lifestyle.
I was bored and had insomnia last night so while drilling a billiard ball for a shift **** (free counterweighted ****....because i'm cheap) i spotted a penny in the recess for the idiot cluster.
I cut the leather wrap off my e-brake handle and then slid the plastic handle underneath off. Penny works splendid. I'll replace it with a bottle cap when i find one worthy.
Old May 29, 2010 | 07:19 PM
no rotor no motor
thanks man
Old May 30, 2010 | 06:00 AM
danegerous's Avatar
Per Formula D rules if you run a hydraulic hand brake it needs to have it's own calipers, allowing the driver to "jab the brakes" and operate the hydro at the same time. Keep that in mind when installing something like this, if it fails, your brakes fail. Hence the dedicated calipers to not interfere with OE brakes.
Old May 30, 2010 | 12:12 PM
no rotor no motor
Dang
Old May 31, 2010 | 03:12 AM
NoPistons!'s Avatar
Tango Down
Cool. More rules. I'm still putting a hydro in my car. I have no desire to go into debt building my car to formula d spec.
Old Jun 6, 2010 | 04:02 AM
driftfcbuckey's Avatar
RX7-Factory
so much fail in that first post...
not only did you waste a penny... but you are now stuck never having an ebrake...
if you remove the little rod/spring when you un-screw your button, you can pull it all out, and then your ebrake is free, and wont/can never lock on its own. one reason why i straight up removed all that crap is because revving to 8k, and dumping clutch with your ebrake ******* stuck up, sucks so bad...
if you remove all that crap, you can still use that bottom lever on the serated little gear thing to lock your ebrake up with ypur finger, and when you want to release it from locked, you just pull the handle up and it releases...
ill post a pic tomorrow. take that crap out before you blow your tranny or DS or some dumb ****.
Old Jun 6, 2010 | 03:39 PM
NoPistons!'s Avatar
Tango Down
It works exactly as he said it does. The ratchet mech can't work if the penny is against the button. Pull the handle off the button and presto, parking brake.
Never having an e-brake? Lol.
Old Jun 6, 2010 | 06:41 PM
no rotor no motor
thank you
Old Jun 6, 2010 | 07:41 PM
lonetlan's Avatar
Too Many Questions
Isn't it funny when "infected panda" did this mod and explained how to have an operational E-brake, but everyone totally overlooked that, until somebody else actually did it?
Old Jun 6, 2010 | 07:47 PM
no rotor no motor
ya
