beauty removed from storage after 19 years!
Old May 25, 2010 | 11:35 AM
slapshot10's Avatar
My darlin's rx
ON beauty removed from storage after 19 years!
Just pulled out the wifes 1981, its been sitting for 19yrs. Amazingly its like the day I tucked it away. Dropped and replaced the oil and filter, emptied the tank of 19yr old fuel, pulled the plugs and put abit of oil in each chamber and replaced the cleaned plugs. Turned it over and I have compression.I want to get it running before I go any further.
Now what?
Old May 25, 2010 | 12:58 PM
jjcobm's Avatar
Are you experienced?
Check hoses for cracks, rubber will crack with age. If coolant was in it make sure it didn't corrode the internals and radiator. If all looks good, start her up...
Old May 25, 2010 | 01:39 PM
evot23's Avatar
Classy
+1 but holy crap 19 years?!?
Old May 25, 2010 | 01:47 PM
Gurew's Avatar
pictures?
Old May 25, 2010 | 02:05 PM
slapshot10's Avatar
My darlin's rx
pictures to come, the damn thing started, very rough though. A mouse has made a home in the exhuast.
Old May 25, 2010 | 02:09 PM
Gurew's Avatar
stupid mouse....
Old May 25, 2010 | 02:24 PM
slapshot10's Avatar
My darlin's rx
stupid me , a tinfoil ball 19yrs ago would have saved me having to remove the muffler now.
Now that i know it runs, SHOULD i BUY STOCK OR REPLACEMENT PART? eg. clutch slave and master and so on.
Old May 25, 2010 | 02:27 PM
Gurew's Avatar
if i were you i would do a complete overhaul..100% new hoses, new spark plugs and spark plug wires, new air filter, new oil filter and oil, replace the brake fluid, new gas, new master and slave, maybe rebuild the brake master, etc... sure thats not all cheap but....its well worth it trust me
Old May 25, 2010 | 02:35 PM
slapshot10's Avatar
My darlin's rx
that is the plan. Had to see if the engine would turn first. Would you reccommend new masters or rebuilding. I know the slave is gone on the clutch.
Old May 25, 2010 | 02:40 PM
Gurew's Avatar
well new is always easier, rebuilding is more fun..really depends on your mechanical skill...
Old May 25, 2010 | 02:48 PM
slapshot10's Avatar
My darlin's rx
Its been awhile since I swore off working on our everyday vehicles (can only wrap so many pop cans around exhaust pipes or replace starters in 2 ft of snow), but this one is for fun. I am really excited about this!
Old May 25, 2010 | 06:40 PM
RX7redlinez's Avatar
Pictures?
Old May 25, 2010 | 07:26 PM
jjcobm's Avatar
Don't forget your rubber fuel lines and brake lines to the caliper. You don't want those exploding because they have been sitting for 19 years.
By the way, why 19years? Was this thing fermenting or what?
Also as far as the clutch master and slave, just get a new one or a good quality remanufactured. It will save you the time and headache in case the rebuild fails (which happens).
Old May 25, 2010 | 08:37 PM
slapshot10's Avatar
My darlin's rx
thanks for the advice, please keep it coming.
WHY? The first child arrived 19 yrs ago, and 2 seats were not enough. It is that simple, we had a place to store it so we did!
Old May 26, 2010 | 10:34 AM
Kentetsu's Avatar
Here is a thread on bringing your 7 back to life after storage: https://www.rx7club.com/showthread.p...postid=2385473
Best of luck with your project. And get some pics!
Old May 26, 2010 | 03:07 PM
argh's Avatar
Rotary Fresh
We have to see pictures of this bad boy
Old May 28, 2010 | 03:18 PM
slapshot10's Avatar
My darlin's rx
I need help. Fuel pump is working ,fuel to the carb, but no fuel flowing into the ports. What is going on?
Old May 28, 2010 | 08:57 PM
Kentetsu's Avatar
Float needles are stuck. Try banging on the top of the carb with a plastic hammer, or something else that won't damage it. That will sometimes shake them loose.
Lots of good reading on the carb for you www.sterlingmetalworks.com
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
