buying a single turbo rx-7, what to check for?
Old Jun 22, 2002 | 11:46 PM
magnum's Avatar
Newbie
Question buying a single turbo rx-7, what to check for?
I am about to buy a single turbo rx-7 and i am wondering what i need to check for to make sure the car is in good working order. Tommrrow i plan to take it to a mechanic to get a compression test done on the engine, anything else i should look out for?
Old Jun 23, 2002 | 01:29 AM
I would make sure that the owner of the car has upgraded the fuel system. Also see if the injectors have been changed.
Old Jun 24, 2002 | 01:07 PM
Jim Swantko's Avatar
See how many motors (if any) it's been through. That's a great way of knowing how the tuning is. If it's been blowing up with the previous owner... there's a good chance it will with you too. It will let you know if you need some dyno time... or if tuned safely... you won't have to worry.
Other than that... Make sure it's got fuel, and the typical other mandatory upgrades these cars need.
Old Jun 25, 2002 | 02:44 AM
Pedestrian X's Avatar
SpAz!
take t for a nice rip aroudn the block. it will tell ya more then you would think.
sherff
Feb 24, 2019 12:09 PM
cam_7779
Aug 18, 2015 07:48 AM
