West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Coolant seal tester? anyone or shop have one?
Old May 20, 2010 | 03:09 PM
PhatManBUD's Avatar
Hey guys, i started workin on the FD again, and i have the motor down to the short block. I want to test to see if my coolant seals are still good before i put the motor back in the car.
Does anyone know any shop that has this tool that can test it for me for cheap? or does anyone have it i can pay you to borrow it? I dont feel like spending $60 for a tool im only gonna use once, and in the event it actually is blown sounds like a waste of $60.00 that could go towards the rebuild if it needs one
Old May 20, 2010 | 06:10 PM
Tom93R1's Avatar
gross polluter
I am pretty sure Autozone has one you can rent for free, just pay the deposit and get it all back when you return.
Old May 20, 2010 | 06:19 PM
ReZ311's Avatar
KM48 Burnout
I think harbor freight has them too with multiple adapters for ZGermans, Japanese, American cars.... GL.
Old May 21, 2010 | 09:55 AM
PhatManBUD's Avatar
thanks guys, but the motor is on the ground stripped down to just the short block.
i was lookin for something like this http://atkinsrotary.com/store/catalo...t-p-16858.html
http://www.pineappleracing.com/cooli...estercspt.aspx
i was hoping someone or some shop would have something like it locally before i have to make the purchase
Old May 21, 2010 | 04:00 PM
finishline's Avatar
Not Even Foo
bump. GL finding one bro! i need to stop by autozone to get a pressure tester myself. the coolant leak gremlins are after me.
Old May 21, 2010 | 06:01 PM
ReZ311's Avatar
KM48 Burnout
I think you answered your own question.
Did you pinch a coolant seal or something?
Old May 21, 2010 | 10:15 PM
PhatManBUD's Avatar
haha well im looking for a cheaper route first.
Its a long story but what happend was, my car wasnt making power i didnt know why, i thought it was maybe a cracked apex seal, and also the water pump went dead. So even tho it was still running, i decided im just gonna pull the motor out and look for the problem. while pulling it in the garage the car started to climb on the temp and overheat before i shut her down.
While pulling it out and tearing it down i found the culprit of me not making power on the turbo manifold. So i checked the compression and its all cool. But since the motor is outta the car i wanna check if the coolant seals are still good after that overheating, before i go through the trouble of putting the motor back in the car. The motor only has 10k on a fresh rebuilt so i dont wanna pull it apart if i dont have to. So my only option is to check if the coolant seals are still good. Then i can put it all back in and be driving again!
ZaqAtaq
Sep 5, 2015 08:57 PM
