Haltech How Hard is it to install the Haltech.....Really??
Old Jun 22, 2002 | 02:38 PM
rx7superman's Avatar
Hi, I've seen pics of this done at several web sites but does anyone out their have real life time actually installing that bad boy? The box comes with what seems to be miles of wire and sounds very complicated to do. Is it worth trying to do it myself or paying a company 1500-2500 to install & tune? I'm not going to be doing the tuning, I'll have to take it somewhere for that but I figure if I could install the Haltech myself I could save myself some cash........thats if I don't blow the motor cause I wired somrthing wrong........
Old Jun 22, 2002 | 05:45 PM
HWO's Avatar
HWO
inteligent extratarestril
if you can follow a dot to dot but do it with wires instead of a pencil, then you should be able to do the install yourself
is your car a fc or fd?
the wiring into a FC can be found on hitmans page, after following his instrutction on his page my car started first pop.
if you can put in a stereo you can put in an E6K
Old Jun 22, 2002 | 08:55 PM
RETed's Avatar
Wow, $1,500 - $2,500 just to install and tune???&nbsp Man, I'm not charging enough!&nbsp I charge $500/install and $500/street tune myself...
-Ted
Old Jun 22, 2002 | 09:43 PM
Hi...Its an FD. Do you need the factory wire harness? Or just the connectors? Ya over here in florida the shops want some arms & legs for their work. I've heard of some guys that will do it for around 500 but I don't trust them with my car....cause they are'nt big shops but guys who race their own cars and know their ****. I just can't take that car to just anyone. Is their a website that has a true step by step process? Thanx for the input.
Old Jun 22, 2002 | 11:05 PM
TonyTurboII's Avatar
Glock Lover
I havent seen any sites like that for an FD. The Haltech will come with its own harness, depending on which one you pick, it will either have all the connectors attached, or you'll have to attach them yourself. HWO is right, if you can put in a stereo, you can put one in. Im going to be installing my own.
Old Jun 23, 2002 | 09:07 AM
Autronic#1's Avatar
How much interest is there for an adapter loom so you can simply plug the haltech into factory ecu plugs and make minor under hood changes
Chris
Old Jun 23, 2002 | 11:16 AM
Brad's Avatar
dear baby jesus...
K2RD already makes a plug n play harness...but the ****** is $450 !!!!!! If you want to go that route you could just splice the wires into the stock harness in the passenger kick panel. Instructions here... http://www.ricemobile.net
I kinda did a mix of both. I removed the stock engine harness which has the #3 & #4 stock ECU plugs on it. Then I ran the Haltech wires for the crank trigger, injectors, MAP sensor, coolant & air temp sensors, BAC, TPS, O2 sensor and radiator fans into the motor bay and soldered them to the stock connectors. I wired the ignitors, fuel pump, road speed, and tach signal into the sotck connector #1 in the kick panel.
Old Jun 24, 2002 | 01:08 AM
HWO's Avatar
HWO
if you are in florida, go and see Crispeed.
Old Jun 24, 2002 | 06:33 AM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I put power to my Haltech last night, pretty uneventful, I powered it up and everyting works...Max
Old Jun 24, 2002 | 03:08 PM
Glock Lover
Good job Max, I cant wait to install mine.
Old Jun 24, 2002 | 05:40 PM
rxrotary2_7's Avatar
Bacon and i were drinking a little one day and did his in about 5hrs or so...correct me if i am wrong Len.
he had the flying loom. easy *** instal. i hve the terminated harness but do not have the time to put it in right now.
like Ted said...WOW! $2500....
Old Jun 24, 2002 | 08:27 PM
Geee.....You guys make it sound easy!
I'm going to do alot of searching and reading. If I get the nerve to do it I'll let you guys know how it went. Thanx for all the info.
Old Jun 24, 2002 | 11:05 PM
Bacon's Avatar
IRS 4 Life
i alomst wished i was drinking alot so i wouldnt feel the burn on my foot...lol but yea 5hrs to get it in rough..i actualy just finished it all up tonight and finished tie-ing in the main power and loading the maps and what not...all sensors check out and looks good so far....
only thing i noticed wierd was my oil press sensor was readint 120 (pegged) psi..mabe its b/c is a brand new sensor on a unfired motor???
Old Jun 26, 2002 | 07:26 AM
I think you should be glad you werent drinking A LOT! you would have "brown streaks of burnt skin" on your legs, arms, face, scalp....LOL
i forgot about that. hows it feeling?
Old Jun 26, 2002 | 08:55 AM
Bacon's Avatar
IRS 4 Life
alot better to say the least..like 90% HEALED
any idea on the oil press sensor? when i unhook it and cycle the key it will read 0 but hooked up it peggs...is it just b/c its never seen any oil press yet?
guess ill have to start it to find out....
Old Jun 27, 2002 | 06:25 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I did about 65% of mine last night, and it was very very easy. I could have done it with my eyes closed. I install car stereos professionally and I have done alarm/remote starter combos that were harder
Now the usuage and tuning might be a different factor all together, but we'll see
The TPS on the Cosmo 13b-re throttle body REALLY SUCKED, still havent figured it out yet
Old Jul 1, 2002 | 01:28 PM
spyfish007's Avatar
Yellow Dragon is no more
Bacon:
Be sure you got your oil pressure connector right ... ie didn't connect your coolant temp connector on the oil pressure sender. They are in real close proximity and they have the same connector. With a stock engine wiring harness you can't mix them up because the coolant temp connector is not long enough to reach the oil pressure sender but if you were cutting and splicing wire ....
Carson
Old Jul 2, 2002 | 12:13 AM
Glock Lover
Where the hell is the oil pressure connector? I thought it was on the side of the housing. Is it totally different for 3rd gens? Maybe the coolant temp connector is in a different spot...
Old Jul 2, 2002 | 12:48 AM
spyfish007's Avatar
The oil pressure sender and the stock coolant gauge sensor are both on that rear cast housing. They are very close together.
Old Jul 2, 2002 | 01:20 AM
Glock Lover
Hm, my coolant temp sensor is built into the waterpump housing.
Old Jul 2, 2002 | 01:28 AM
spyfish007's Avatar
3rd gen water housing has three items .... level sensor, radiator fan thermoswitch, and ecu coolant sensor.
Old Jul 2, 2002 | 01:30 AM
Glock Lover
Oh your talking about the gauge sender, not the ECU one. Doh.
Old Jul 2, 2002 | 01:35 AM
HWO's Avatar
HWO
yeah, its a bit of a let down when you are expecting to fry wires and see smoke pouring from something ahhaha
Old Jul 2, 2002 | 02:19 PM
Jaymz's Avatar
Re: How Hard is it to install the Haltech.....Really??
Is there a complete list of Haltec install writeups? Which one is the best for the 3rd gen?
Old Jul 2, 2002 | 02:29 PM
Jaymz's Avatar
