PICS!!! Dual Alternator Pulley Install
Old Jun 22, 2002 | 08:18 AM
banzaitoyota's Avatar
What Subscription?
Here are some pics of the Dual Alternator pulleys Install on a S5 engine:
You can also see pics in this thread:
https://www.rx7club.com/forum/showth...threadid=89277
Old Jun 22, 2002 | 09:49 AM
gz91rx7's Avatar
This may sound stupid but what is the advantage of that set-up? To run your electronics more efficiently?
Old Jun 22, 2002 | 09:51 AM
jspecracer7's Avatar
1JZ powered
and also get rid of the smog pump...
Old Jun 22, 2002 | 10:08 AM
What Subscription?
Nope, not a stupid wuestion at all. The purpose is to maximize cooling system performancewhen:
You have removed your cats and your 6 ports, hence eliminating the need for the air pump.
When you remove the air pump, the engine will only have 1 belt driving the water pump. This one belt will slip decreasing cooling system effienciency. Here is a photo of the stock set-up, now compare it to the pic above.
Old Jun 22, 2002 | 10:15 AM
What Subscription?
Forgot the pic.
Old Jun 23, 2002 | 03:06 AM
Funklord's Avatar
i got a little belt and put it on just the main pulley and the water pump. it gets about 3x more contact than any other setup
Old Jun 23, 2002 | 04:16 AM
SonicRaT's Avatar
Super Raterhater
How hard was it to change the pulley? I really need to do this to my GXL sometime soon.
Old Jun 23, 2002 | 04:24 AM
1JZ powered
Need to? Man, the effects are minimal...but you'll need an impact gun to take off the free spinning nut off of the alternator. I think a 14mm wrench and/or14mm socket w/ ratchet and a block off plate...
Old Jun 23, 2002 | 04:27 AM
TonyTurboII's Avatar
Glock Lover
I dont understand how you couldve done that. The water pump allows no adjustment for belt tension.
SonicRaT's Avatar
Super Raterhater
Haha, I have NO other belts on my car, I think it'd be a good idea
Old Jun 23, 2002 | 05:17 AM
Juan's Avatar
Im a tall midget.
Do a search for "yahoo belt" or "yoohoo belt" Both of these terms are in the same thread. I have one of these belts on my car and it worked very well. Belt costs like 3-4 dollars. Sure its not as cool or as good as a dual-belt pulley but it does the job.
Old Jun 23, 2002 | 06:54 AM
Funklord's Avatar
you have to use a screwdriver ot something to get it on
it takes a little muscle, but it works good.
LunchboxCritter
15
Jan 3, 2016 04:11 PM
The Shaolin
Sep 14, 2015 07:50 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
