West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
use or not to use that is the question??????
Old May 13, 2010 | 12:59 AM
cosmo7's Avatar
BRAP!!
Question use or not to use that is the question??????
im rebuilding my 87 turbo II and i dont want it to blow if i should buy a new rotor housing. should i buy 1 or will this be ok?? help me out.
Old May 13, 2010 | 10:29 AM
cosmo7's Avatar
BRAP!!
Need help my rotary brothers
Old May 13, 2010 | 10:42 AM
DivinDriver's Avatar
1st-Class Engine Janitor
Tough call; new would be better, but obviously $$.
It doesn't look from the picture like it's gotten into the water-jacket seal surface, though it's close. If there's no inner thinning in the direction toward the rotor chamber, you could probably grind the corrosion out carefully and JBWeld it... It's strictly in the waterjacket to tension bolt barrier as far as can be seen by the picture, and so doesn't carry much pressure.
Any place the water seal touches has to be absolutely flat, though. Otherwise you're inviting a water leak.
Old May 13, 2010 | 11:14 AM
Chris_V's Avatar
=o
do it right or do it twice.
Old May 13, 2010 | 12:40 PM
cosmo7's Avatar
BRAP!!
yee im getting a new 1 thx
Old May 13, 2010 | 12:54 PM
Battle Cat's Avatar
Space cadet
new one
Old May 13, 2010 | 01:12 PM
stormshadow531's Avatar
I break cars.
i know a guy who has a used housing if you need one.
Old May 13, 2010 | 01:14 PM
rotary#10's Avatar
Vodak
Amen.
Old May 13, 2010 | 03:29 PM
And sometimes, both!
Old May 14, 2010 | 03:53 AM
DC 91 fc3s's Avatar
INNOVATOR NOT IMITATOR
+1 ^^ haha and in some occasions three times
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
