Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek rtek 2.1. will it work with my turbo setup?
Old May 12, 2010 | 09:22 PM
bikeboy23332's Avatar
ive been thinking about options for my TII after it has been broken in. i was wondering if any of the guys that use the 2.1 rtek could help me with some input as to how well it would work on my setup.
significant internal mods
street port- pineapple racing template ( mild )
D shaped exhaust ports - pineapple racing template
atkins 3mm apex seals- corner seals
mods
hks manifold
tial 41mm wg
tial 50mm bov
Borgwarrner GM8 turbo. 70-1
this is what im wondering most about.
here is some info on the turbo. they said its similar to a garret stage 1 and i believe a to4s idk for sure.
http://www.mx6.com/forums/1g-mx6-for...-gm-1-8-a.html
fmic is going in soon
innovate WB02
Old May 13, 2010 | 12:27 PM
tigerbite's Avatar
It will work fine with your setup. You will need larger injectors if you want to boost higher than stock. What are your power goals?
Old May 13, 2010 | 07:47 PM
at least 300 hp is what i would want.
id like 330 hp
i have 720cc in the secondaries now. i will prolly move them to the primarys and get 1000cc for the secondaries. thoughts?
anyone else.
Thanks
Shane
Old May 14, 2010 | 12:01 AM
Silverfc88's Avatar
Is the wastegate hole plate only held on with silicone?
Old May 14, 2010 | 08:29 AM
no the down pipe covers the hole also, silicone was just so it didnt fall out for a bit
smikels
Rtek Forum
May 12, 2016 12:34 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
eddierotary
Rtek Forum
Aug 25, 2015 05:48 PM
smikels
Aug 18, 2015 01:26 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
