Emissions
Old May 9, 2010 | 09:11 PM
scott.florschuetz's Avatar
Wheelaholic
Emissions
I have stripped plenty of 12a's down but i have never played with a GSL-SE. I have removed the smog pump, AC, Power steering Pump (broken). What all can i remove from the motor I.E. vacumm lines, solenoids. ETC...
Old May 9, 2010 | 10:07 PM
Rehd's Avatar
Push The Button
Dude i have searched and searched and cannot find the answer, i do know the cold start assist stuff can go.
Since you removed the air pump you have to find a way to actuate your 5th and 6th ports, its not that hard but a little searching is involved.
Old May 9, 2010 | 10:35 PM
Wheelaholic
can they be removed or wired open like the 2nd gens?
Old May 10, 2010 | 09:41 PM
Rehd's Avatar
Push The Button
Yes they can be wired open and i assume they could be removed, though i have never heard of anyone doing that before. I find most people either use the air pump to open them or use an rpm switch and set it up electronically.
I forgot to say you can also remove your air control valve on the lower intake manifold, replacing it with a block off plate and i believe (though i may be incorrect) but the solonoids in the rear, passenger side of the engine bay with vacuum lines attached to the air control valve (acv) can be removed also.
The s3 and s4 engines are very simular in most ways but the emission system is different in the s4 bacause of the change in emissions standards at the time.
Old May 12, 2010 | 09:36 PM
Rehd's Avatar
Push The Button
If anyone has any input at all, please help out.
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
