Gsl-se
Old May 9, 2010 | 09:09 PM
scott.florschuetz's Avatar
Wheelaholic
Gsl-se
OK so i bought a 84 GSL-SE Car has 67,000 Miles on it and is in GREAT condition for its age. I got it home and re-assembled the fan/shroud. and went to start it up. It started fine, but will not idle At all. I kept it on for a few minutes and turned it off and then it wouldnt start back up. I pulled the plugs and they were soaked. So it is being flooded. Now heres a couple of things that contribute (i think) the FPR Solenoid is missing (both vacums just left open) and there is no gas cap. I have changed the fuel filter and when it does run, it runs great. but i wont stop flooding. Any ideas? is there a way to bypass the Solenoid and run without it? Does the gas cap have anything to do with this?
Old May 9, 2010 | 09:50 PM
Whisper's Avatar
If it's getting flooded after you turn it off, then fuel is getting into the engine somehow. It's possible your injectors are leaking a bit. Also you do need the FPR solenoid. FPR is controlled by the vacuum. Not to mention having vacuum lines just hanging open is no good, and it's probably why it won't idle. Try plugging them up, at least.
Old May 9, 2010 | 11:00 PM
aoc_pilsener's Avatar
are u using the fuel pump shut off switch on the dash?
Old May 10, 2010 | 05:11 AM
Wheelaholic
?? Fuel Pump Cutoff Switch?
Old May 10, 2010 | 11:26 AM
Whisper's Avatar
Some people install a fuel pump cutoff switch, it's not something that comes stock on the car, though, so I doubt you'd have one.
Old May 10, 2010 | 03:48 PM
trochoid's Avatar
Old Fart Young at Heart
With the low mileage and condition if the car, I suggest putting everything back stock and sending the injectors out for service. Sounds like they're leaking, causing the flooding. With that low of mileage the car has sat a lot, a can of Seafoam wouldn't hurt. Also check that the Aux ports are still working.
Old May 10, 2010 | 10:02 PM
1coolmazda's Avatar
I agree with trochoid try some sea foam my GSL-SE did that one time and my sat for a couple of years before I bought it. Mine had 103,000 miles on it. After I bought it I put A can of sea foam in it and never had a problem with it since.
Old May 10, 2010 | 10:46 PM
Wheelaholic
i hvae a can of sea foam in it now but i cannot get hte car to stay on (idle) if i hold the gas it is fine, but as soon as i let go it shuts down.
Old May 10, 2010 | 11:11 PM
Whisper's Avatar
It likely shuts down due to a massive vacuum leak, as both your solenoid vacuum lines are hanging open.
Old May 11, 2010 | 05:29 AM
Wheelaholic
Solenoid lines plugged.. I kept the car at 3K rpm's and sprayed it down with carb cleaner and it picked up no leaks.
Old May 13, 2010 | 06:36 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Leaky injectors, as another poster has stated.
The trick about the fuel injector 'cutoff switch' is a good one; it allows the driver to control when the fuel injectors fire, and subsequently allows the driver to turn off fuel flow if the engine is believed to be flooded. Cranking on the dry engine then airs it out.
The fuel injectors will not fire if they don't see a trigger signal from the Leading Ignitor. The Leading Ignitor only fires when the engine is turning the distributor shaft. The Trigger Wire is a single white wire attached to the lower spade terminal on the front Ignitor at the driver's side strut tower. Install the switch on the white wire if you're so inclined, or just know to disconnect it when the engine is flooded. This will shut off the injector pulses, but you'll still have fuel pressure.
An alternate method is to install a fuel cut switch on the Fuel Pump fuse under the driver's side dashboard. This effectively shuts off all fuel flow, though the injectors will still fire, but won't have fuel pressure - so it effects the same end result.
Solution #1 above won't isolate leaky fuel injectors. Solution #2 above will, as it shuts down fuel pressure entirely.
Isolating the problem is the trick, and using a fuel cut switch or injector cut switch is just a workaround to help with engine flooding (the symptom), while not really fixing the problem (leaky injectors). HTH,
Old May 14, 2010 | 05:57 AM
RotaryRevn's Avatar
do you mind telling us how much the car was?
Old May 14, 2010 | 07:18 AM
Wheelaholic
$$850
Old May 14, 2010 | 10:55 AM
Tobias's Avatar
Old Car, Young man
I 100% agree with the leaking injector theory.
I would also make sure you check to make sure that the injectors are receiving a pulse. On my GSL SE the injectors were 100% clean and balanced and not leaking, but there was a bad ground and it was keeping an injector wide open while the other one was still pulsing. I thiiink theres also a fuse on the ecu that controls that, and it may be worth checking. (Some one with more knowledge then I could confirm that)
Old May 14, 2010 | 02:47 PM
LongDuck's Avatar
If injectors lose their ground, they don't fire.
This occasionally happens when the wiring harness gets old or corroded and the fuel injector bungs lose contact where they enter the harness. This usually results in the 'running on one rotor' symptom of SE's.
Borg-Warner replacements were only $7 each, and if you're going to do one - do both. Cheap insurance.
Old May 14, 2010 | 03:23 PM
Whisper's Avatar
Yeah, or Napa's Echlin ones, I think they're even cheaper... Part #2-17427. Your old ones will probably crumble into bits when you disconnect them anyway.
Old May 14, 2010 | 03:49 PM
RotaryRevn's Avatar
Originally Posted by scott.florschuetz
$$850
Damn man, great deal! I wish I could find something like that.
NickNac113
13
Oct 1, 2015 09:25 PM
