Microtech connecting with windows vista
Old May 9, 2010 | 10:18 AM
arc_55's Avatar
Exclamation connecting with windows vista
hey guys i have been using an older laptop because i cant seem to connect with windows vista. The program opens and then as soon as i attempt to connect to the microtech the program freezes and then eventually i have to exit. I know the doggle and everything works perfect on the older laptop so i know it has to be a windows vista issue.
Anyone have any experience with vista and microtech?
thanks for the help in advance too bad the microtech website forums are down
Old May 11, 2010 | 08:04 PM
Boost or Bust's Avatar
Rotorhead in the making.
I had the same problem with Vista in the past. I think if you right click and check the properties you can run it in XP mode. It still didn't work very well for me. I would recommend sticking to the old laptop.
Old May 12, 2010 | 04:33 PM
rx72c's Avatar
Top Answer: 1
I have no problem with vista. I found most people are having problems with their usb to serial convertor.
Old May 12, 2010 | 08:19 PM
pistones's Avatar
i had the same problem and it was cured by downloading a different usb driver. i don't remember exactly which one, but basically windows 7 needs all different drivers from previous windows.
befarrer
15
May 19, 2022 10:44 PM
toplessFC3Sman
Mar 20, 2018 01:54 PM
