Connector in Door Behind Plastic?????
Old Jun 21, 2002 | 04:09 PM
banzaitoyota's Avatar
What Subscription?
Ok Wiring Guru's:
I removed the Passenger side Door panle on my 86 GXL. Behind the clear plastic moisture shield is a 2 prongged connector. What is the purpose of this?
Pics later. Thank you for your time!
Old Jun 21, 2002 | 05:19 PM
What Subscription?
Here it is behind the plastic:
Old Jun 21, 2002 | 05:23 PM
What Subscription?
I have the pliers pointing to it.
Old Jun 21, 2002 | 06:32 PM
[bnd]'s Avatar
I'm guessing it's for the door lock cylinder. The little ring that lights up around the key hole.
Old Jun 21, 2002 | 07:43 PM
What Subscription?
It wasn't connected to anything?????
Old Jun 21, 2002 | 08:28 PM
Felix Wankel's Avatar
Super Newbie
Do the power locks work? I unplugged that plug replacing my outside door handle, but I can't remember what it was for.
Old Jun 21, 2002 | 08:34 PM
What Subscription?
Yes power door locks work.
Old Jun 21, 2002 | 08:36 PM
Icemark's Avatar
what are the wire colors?
Old Jun 22, 2002 | 08:20 AM
MtnRacer's Avatar
infini guru
Were illuminated door lock cylinders an option? Could be just an empty spot on the harness for a feature your car didn't come with... Man, I am so tempted to go take apart my door right now!
Steve
Old Jun 22, 2002 | 08:22 AM
What Subscription?
Thats the best explanation so far. There is also another set about 1 fott forward on the door!
Old Jun 22, 2002 | 09:32 AM
MtnRacer's Avatar
infini guru
Ok, I couldn't resist....
First off, I have a '90 TII, and it looks as though our wiring harnesses may be a little different. But here's what mine looks like:
The first connector to the left also goes to the power window unit, and supplies power(I think).
The second connector in the middle which has black and blue wires coming FROM it go to the door lock cylinder light. This is the connector I think you are pointing your pliers at.
Finally, the third connector on the left, which has a Red and Green wire coming FROM it goes to the power windows, I am assuming it sends control signals(what the hell, I have a 50/50 shot at being right, right?).
I also checked further up the door near the front of the car, and found a few connectors that might be the one you were wondering about, it's either power locks, or a doorwoofer connection. I can post more detailed pics if you need them. I am fairly certain that I'm correct, but as I said in the beginning, our wiring harnesses look a little different, so I could be totally wrong. Hope this helps!
Steve
Old Jun 22, 2002 | 09:34 AM
MtnRacer's Avatar
infini guru
P.S. I also just noticed that the door cylinder light connector is mounted in pretty much the EXACT same spot the connector you're talking about is... I am thus further convinced!
Steve
Old Jun 22, 2002 | 10:36 AM
Sniper_X's Avatar
It IS the lock cylinder light wire.
Sorry I didnt see the thread sooner, I could have saved you opening your door to check for him!
Old Jun 22, 2002 | 01:22 PM
What Subscription?
Steve thanks a lot. Thanks you guys. Now I just have to find a set to mount in the GXL.
