Losing brake fluid - rebuilt slave cylinder
Old May 4, 2010 | 12:32 PM
2007MX5's Avatar
OH Losing brake fluid - rebuilt slave cylinder
Just posting a problem solved which may help or inspire others: I had magically disappearing brake fluid from my master cylinder, with no visible leak. not much on the ground either. finally traced it down to my slave, where the rod boot was full of fluid.
I debated rebuild vs. replace ($15 difference) but I like the sense of accomplishment of DIY. (no one owns an old car who could afford a newer out of convenience) so i disassembled and sure enough the rubber gasket on the piston had a slice in it. wonder how that could have happened? replaced that with a $7 rebuild kit, cleaned the parts with new brake fluid, and works perfectly. no reason to consume new parts! now the rusty exterior of my slave matches everything else under the hood...
Old May 4, 2010 | 03:56 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Well done.
Slice could have been a split; the rubber does age in there.
Old May 5, 2010 | 02:50 AM
7aull's Avatar
RX HVN
Welcome - and Thanks for posting! hear lots of problems - not always happy endings/solutions...
Stu Aull
80GS
Alaska
Old May 5, 2010 | 11:54 AM
mazdaverx713b's Avatar
Have RX-7, will restore
glad to see you got the issue sorted out! its always nice to hear that the newer guys here have good working knowledge!
Old Mar 2, 2011 | 01:52 PM
Dementia's Avatar
I just got an s4 gtu and its doing the same thing. Haven't tried to bleed the brakes yet but the fact that fluid dissapears sounds similar.
rgordon1979
40
Mar 15, 2022 12:04 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
SCinfidel
Sep 8, 2015 05:36 PM
